From A to Zed Posted January 31, 2009 Share Posted January 31, 2009 Hi all, Is it tricky to change the front indicator bulbs? I have bought a set but there appears to be zero/no room to get behind the headlight unit?? Can you loosen the 4 bolts at the top to get some play? Please don't tell me this a bumper off job Quote Link to comment Share on other sites More sharing options...
P15UL T Posted January 31, 2009 Share Posted January 31, 2009 this is a fiddly job but is it possible to reach in and twist the bulb connector to release it , you will scuff your knuckles....good luck oh if you loosen of the top fitting to the light it will allow a little movment of the headlght Paul Quote Link to comment Share on other sites More sharing options...
From A to Zed Posted January 31, 2009 Author Share Posted January 31, 2009 Cheers Paul Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted January 31, 2009 Share Posted January 31, 2009 As above, did mine without removing the headlight, just undo the top bolt and slip your hand down there Quote Link to comment Share on other sites More sharing options...
Stew Posted January 31, 2009 Share Posted January 31, 2009 I did mine without removing too. It's a bit fiddly but have patience and it'll be easy! Quote Link to comment Share on other sites More sharing options...
From A to Zed Posted February 2, 2009 Author Share Posted February 2, 2009 Thanks guys, it was pretty simple in the end but a bit tight! I think I've got some grubby finger prints on the bulbs so I'll be repeating the process soon Quote Link to comment Share on other sites More sharing options...
