Maccaman Posted January 25, 2009 Share Posted January 25, 2009 Just went to pop out & had a unusual occurence on my Zed. On starting the car it just went to fire & then just missed catching. No problem I thought, turned the key & it was not firing, which had me worried. Popped the bonnet just to see if there was anything stupid I could see but as I guessed nothing obvious. In the end I just kept the key turned & it eventually just about caught (didn't think it was going to) & had to let it pick up itself as I felt touching the accelerator would have killed it. Let it warm up before moving off & just went to the shop. Came out and it started like normal. Never done anything like this before and now I'm worried its the start of something, but hope it was just a strange one off. Quote Link to comment Share on other sites More sharing options...
marzman Posted January 25, 2009 Share Posted January 25, 2009 I think mine does this occasionally... but is due to my aftermarket alarm. Rarely it wont start first time, so i have to beep the alarm on and off, then it starts perfectly. I dont know if you have an aftermarket alarm? Quote Link to comment Share on other sites More sharing options...
Maccaman Posted January 25, 2009 Author Share Posted January 25, 2009 No mines stock. Quote Link to comment Share on other sites More sharing options...
martinmac Posted January 25, 2009 Share Posted January 25, 2009 Its not a battery issue then bud. Not that cold today either. Very strange. Apparently if you fail to start the first time you should wait at least 10 seconds before trying again. Quote Link to comment Share on other sites More sharing options...
Maccaman Posted January 25, 2009 Author Share Posted January 25, 2009 Yeah did that. Even after the time looking in the engine bay it still didn't want to start. Quote Link to comment Share on other sites More sharing options...
AUTO EXPRESS Posted January 25, 2009 Share Posted January 25, 2009 had this problem on another car once, turned out to be fuel filter. Quote Link to comment Share on other sites More sharing options...
Maccaman Posted January 25, 2009 Author Share Posted January 25, 2009 Just been out in the car & it started 1st time as normal. Quote Link to comment Share on other sites More sharing options...
Beavis Posted January 25, 2009 Share Posted January 25, 2009 Just been out in the car & it started 1st time as normal. Would not worry about it Keith, mine as done this before if it did not catch first time. Quote Link to comment Share on other sites More sharing options...
bronzee Posted January 26, 2009 Share Posted January 26, 2009 Macca it sounds like it could be the Crank Position Sensor. Common problem, and a lot of the earlier models do it. There was a TSB out in the US for it. Quote Link to comment Share on other sites More sharing options...
nixy Posted January 26, 2009 Share Posted January 26, 2009 Just went to pop out & had a unusual occurence on my Zed. On starting the car it just went to fire & then just missed catching. No problem I thought, turned the key & it was not firing, which had me worried. Popped the bonnet just to see if there was anything stupid I could see but as I guessed nothing obvious. In the end I just kept the key turned & it eventually just about caught (didn't think it was going to) & had to let it pick up itself as I felt touching the accelerator would have killed it. Let it warm up before moving off & just went to the shop. Came out and it started like normal. Never done anything like this before and now I'm worried its the start of something, but hope it was just a strange one off. did you see my post last week? Exactly the same thing happened to me! Now it's fine. Need to check my battery still. Quote Link to comment Share on other sites More sharing options...
Maccaman Posted January 26, 2009 Author Share Posted January 26, 2009 Macca it sounds like it could be the Crank Position Sensor. Common problem, and a lot of the earlier models do it. There was a TSB out in the US for it. Did give me the impression it was something like this (though had absolutely no clue what). Just taken it to the garage to have a Summit brace fitted & new pads and it started normally. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted January 26, 2009 Share Posted January 26, 2009 flooded it. Done it myself when you let go of the key when starting before its caught. Quote Link to comment Share on other sites More sharing options...
bronzee Posted January 27, 2009 Share Posted January 27, 2009 Macca it sounds like it could be the Crank Position Sensor. Common problem, and a lot of the earlier models do it. There was a TSB out in the US for it. Did give me the impression it was something like this (though had absolutely no clue what). Just taken it to the garage to have a Summit brace fitted & new pads and it started normally. If you have a nosey on my350z.com or 350z-tech.com you'll find oodles of threads about Crank Position Sensor. Battery will normally give some warning if it was that. With the Crank Sensor, when you unlock and put the key in the ignition, it just doesn't "crank", give it 30 secs or so, and it usually does. I normally flick the alarm the second time I try. ps. With mine it wasn't the alarm that causes the problem as it did it the first time, the morning the alarm was due to go in, almost 5 years on, it does it occasionally, it is annoying but not keen to put Z anywhere near a dealer if I can help it. Quote Link to comment Share on other sites More sharing options...
