Sunny1 Posted January 21, 2009 Share Posted January 21, 2009 Hi all, Having trouble with programming a new key fob i have brought of e-bay, i have started the steps 1 to 10 as listed below but keep on falling down on step 3 (i have tried about a dozen times or so leaving a short time between each try and locking/unlocking the car each time), i have even got the g/f to look and see if the hazards/warning lights come on, my car is a UK one and it only came with one key, hence the reason why i need another one, i suppose my question is if the car comes with three keys originally would one of the three be a master key which would allow you to programme from using the steps below or would any one of the three keys preform the programming sequence. 1. Turn the ignition switch from Position 0 to ON 6 times within 10 seconds. 2. Then turn ignition switch to OFF position. Leave key in ignition switch. 3. After 2 seconds, the system will enter programming mode and will flash the warning lights twice. 4. Press and HOLD the unlock button on the Plip. 5. While pressing the unlock button, press the lock button 3 times. 6. Release the unlock button. 7. The warning lights will flash once to indicate successful programming. 8. Repeat procedure 4 to 7 for up to 4 plip key’s. 9. When completed turn ignition ON, and the warning lights will flash 2 times. 10. Remove key, and check all plip key’s for operation. Any help would be much appreciated Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted January 22, 2009 Share Posted January 22, 2009 Takes a few tries Quote Link to comment Share on other sites More sharing options...
ab350z Posted January 22, 2009 Share Posted January 22, 2009 And this is what a Nissan dealer will charge £45 + vat to do on each key?? Quote Link to comment Share on other sites More sharing options...
Sunny1 Posted January 22, 2009 Author Share Posted January 22, 2009 And this is what a Nissan dealer will charge £45 + vat to do on each key?? Your right ab350z, i got quoted £51 to have one fob programmed, i then asked how much it was for a new key and the fob programmed...... answer £131 + vat. Quote Link to comment Share on other sites More sharing options...
Ozz Posted January 22, 2009 Share Posted January 22, 2009 Spooky I was going to post up a similar thread about fobs yesterday. Anyone know if this would work on a JDM? If I get the ebay key, can I get it cut at a normal locksmith? Quote Link to comment Share on other sites More sharing options...
Sunny1 Posted January 22, 2009 Author Share Posted January 22, 2009 Spooky I was going to post up a similar thread about fobs yesterday. Anyone know if this would work on a JDM? If I get the ebay key, can I get it cut at a normal locksmith? Ozz i believe you can get it cut from a local lock smith ( i've been told to take my new blade in to Nissan and they will cut it free of charge by one of the managers.... which i thought was nice of him. PS i paid £13.50 for the fob and new blade Quote Link to comment Share on other sites More sharing options...
Unforgiven Posted November 2, 2011 Share Posted November 2, 2011 Ok, did as said in the guide, programmed both keys, the original works fine, unlocks/locks the doors and starts the car but the second key will only unlock/lock but won't start. Am I doing something wrong? Quote Link to comment Share on other sites More sharing options...
sparky370z Posted November 2, 2011 Share Posted November 2, 2011 Quote Link to comment Share on other sites More sharing options...
M13KYF Posted November 2, 2011 Share Posted November 2, 2011 Ok, did as said in the guide, programmed both keys, the original works fine, unlocks/locks the doors and starts the car but the second key will only unlock/lock but won't start. Am I doing something wrong? did you try the guide in GIXXERUK's post in this thread and not the first post Quote Link to comment Share on other sites More sharing options...
Unforgiven Posted November 2, 2011 Share Posted November 2, 2011 Yes, it all worked as stated, lights flashed when supposed to etc, but it seems to have only programmed the remote opening and not the key transponder. Quote Link to comment Share on other sites More sharing options...
Unforgiven Posted November 2, 2011 Share Posted November 2, 2011 Did you know you're the first person to ever post that image on a resurrected thread? Very original and helpful. Quote Link to comment Share on other sites More sharing options...
