photobucket help
P15UL T
hi guys, i hoping that someone out there has the answer to the question, can the videos that you make on photobucket be made larger up to a size of 830 pixcels wide ?
i have upgraded to the pro package which allows you to host larger pictures but i have had no joy with the video side of things
any help would be appricated
cheers Paul :D
depends if the original material is at that size. Normally TV size is 720 pixels wide. Widescreen is more at 1024 pixels wide but it is made anamorphic so the image looks stretched in the Y axis so is actually still 720 pixels, You may have seen this on a telly if its not set up correctly.
The only true way to get over 720 pixels is to film in HD. Then it will be 1920 pixels wide.
