denyer00 Posted January 19, 2009 Share Posted January 19, 2009 Hi guys, I've just bought a 56 plate 350z GT with everything loaded. The car also came with a Dension Ice Link iPod cable. After connecting my iPod it charges but doesn't play through the Bose headunit. Any ideas what the problem could be? Regards Danny Quote Link to comment Share on other sites More sharing options...
AK350Z Posted January 19, 2009 Share Posted January 19, 2009 Needs a cd changer socket to plug in doesn't it? UK Bose systems don't have anywhere for it to plug in as far as i know see the other million threads about the lack of mp3 compatibility in the zed! http://www.350z-uk.com/forum/viewtopic.php?t=17343 Don't forget to post pics of your car in the intro section! Quote Link to comment Share on other sites More sharing options...
Martin W Posted January 19, 2009 Share Posted January 19, 2009 Hi guys, I've just bought a 56 plate 350z GT with everything loaded. The car also came with a Dension Ice Link iPod cable. After connecting my iPod it charges but doesn't play through the Bose headunit. Any ideas what the problem could be? Regards Danny I had 1 of these put in a BMW X3. To play you had to select the CD. and playlist 1 to 6 on the iPod became CD 1 to 6 - might work for you ? Quote Link to comment Share on other sites More sharing options...
AK350Z Posted January 19, 2009 Share Posted January 19, 2009 Hi guys, I've just bought a 56 plate 350z GT with everything loaded. The car also came with a Dension Ice Link iPod cable. After connecting my iPod it charges but doesn't play through the Bose headunit. Any ideas what the problem could be? Regards Danny I had 1 of these put in a BMW X3. To play you had to select the CD. and playlist 1 to 6 on the iPod became CD 1 to 6 - might work for you ? They probably just hooked up the power Bmw cd changer was probably external, so there would have been a socket to plug into. Bose cd changer is built into the head unit. According to Denison: Compatible Nissan Radios: Nissan Blaupunkt radios with a square (8-pin) Mini ISO CD changer socket at the rear. Connection of the ice>Link is made via the mini ISO CD Changer connection found on the rear of the radio. Quote Link to comment Share on other sites More sharing options...
Martin W Posted January 19, 2009 Share Posted January 19, 2009 Hi guys, I've just bought a 56 plate 350z GT with everything loaded. The car also came with a Dension Ice Link iPod cable. After connecting my iPod it charges but doesn't play through the Bose headunit. Any ideas what the problem could be? Regards Danny I had 1 of these put in a BMW X3. To play you had to select the CD. and playlist 1 to 6 on the iPod became CD 1 to 6 - might work for you ? They probably just hooked up the power Bmw cd changer was probably external, so there would have been a socket to plug into. Bose cd changer is built into the head unit. According to Denison: Compatible Nissan Radios: Nissan Blaupunkt radios with a square (8-pin) Mini ISO CD changer socket at the rear. Connection of the ice>Link is made via the mini ISO CD Changer connection found on the rear of the radio. Just a suggestion bud! - having some experience of dension !!! no guarantees, just trying to help Quote Link to comment Share on other sites More sharing options...
AK350Z Posted January 19, 2009 Share Posted January 19, 2009 No probs, didn't mean to be harsh, just typing too fast to add niceties! Quote Link to comment Share on other sites More sharing options...
M13KYF Posted January 20, 2009 Share Posted January 20, 2009 this should help http://www.350z-uk.com/forum/viewtopic ... ht=dension Is it just that you need to tune in the correct FM frequency Quote Link to comment Share on other sites More sharing options...
denyer00 Posted January 20, 2009 Author Share Posted January 20, 2009 seems a bit strange how they would just hook it up to power an iPod! Why would they do such a thing, suppose i could use it as an iPhone charger. Quote Link to comment Share on other sites More sharing options...
denyer00 Posted January 20, 2009 Author Share Posted January 20, 2009 Thank god! Just figured it out, it's hard wired to the aerial so I just go on 88.8 FM and it works! Sweet! Sound quality is good suprisingly, not as loud as CD but acceptable, I got the iPod's built in EQ to give more treble and it sounds much better. A lot better than the usual FM transmitters. Cheers for the response Danny Quote Link to comment Share on other sites More sharing options...
M13KYF Posted January 21, 2009 Share Posted January 21, 2009 Thank god!Just figured it out, it's hard wired to the aerial so I just go on 88.8 FM and it works! Sweet! Sound quality is good suprisingly, not as loud as CD but acceptable, I got the iPod's built in EQ to give more treble and it sounds much better. A lot better than the usual FM transmitters. Cheers for the response Danny nice one!! what I said then, check to see if you've tuned in correctly Quote Link to comment Share on other sites More sharing options...
