Wheel sizes....
Adriank
Would any of these wheel sizes be ok to use on the Z:
18×9.0J ET 32 5H-114.3
18×9.0J ET20 5H-114.3
18×10.0J ET32 5H-114.3
18×10.0J ET18 5H-114.3
I was thinking about 18x9 on front and 18x10 on rear?
Weds Sport SA-70's
I'm guessing with these sizes you wont be needing spacers! Low offset and a wide wheel, would it rub any u think?
Also what size tyres would you reccomend on wheels that size?
Also has anyone thought of using 18" front wheels and 19" rear wheels. I know those type G Rays came like that on those cars...
Weds Sport SA-70's
nice, where did u see those :thumbs:
Won't need spacers. Shouldnt rub, I'm running 10.5" in the back lowered on coilovers with no rubbing issues.
Weds Sport SA-70's
Tom @ TGM can get most of the jap brand wheels shipped in, ive been trawling to find some i like in sizes that fit so i can get some prices from him.
+1 I had the same widths and offsets in 19" with 245F/275R tyres and no rubbing.
the question of will it/won't it rub will not be the same for everyone
here is why
1. the Z comes from the factory with a range of alignements. Not all cars have the same camber/toe specs. Where the car starts off spec wise, determines where it ends up once it's lowered. The rubbing issue is in the rear, not the front by the way
2. Not all tires of a given size have the same physical dimensions. A 275/40 T1R is not the same as a 275/40 Potenza RE050 or S03. The differences can be substantial. Example. In the Work thread I posted. My car was at that exact height, with those exact wheels. With Toyo's (at the time T1S), I never once rubbed. Toyo's wore out finally so installed the S03's - the car rubbed over every single bump, no matter how small. The S03 were the same size as the Toyo, but the S03 were substantially bigger. No amount of camber I tried prevented the rubbing. So, I rolled the fenders and never had to think about it again
The only way to guarantee no rubbing is to either fit a wheel so conversative that there is no chance of it ever rubbing (ie a 9.5 with a +30 offset for example with a reasonbly sized tire) no matter what the height/alignment. Or, to simply fit the wheel, hope for the best, and if it rubs. have the fenders rolled. Thankfully rolling the fenders is neither difficult nor particularly costsly, so it's quite easy to solve the potential issue
