RICHIERICH Posted January 13, 2009 Share Posted January 13, 2009 Hi Guys, Recently my headlight washers have stopped working, from the button aswell as windscreen. I thought it might be cold temp. So I checked fuse that was good so thought it might be relay? I thought i'd top my windscreen wash up as it was low, after that they worked, off windscreen wash and on demand from button. I would have a good guess that there is a level sensor in bottle, to save for windscreen when low. You may or may not of known this, regards Richard. Few pics to show where fuse/relay is located for headlight washers just incase the fuse has ruptured. You will need to remove trim around battery to expose the fuse box Quote Link to comment Share on other sites More sharing options...
Darren-B Posted January 13, 2009 Share Posted January 13, 2009 The main water tank is split, when the level drops down low it stops the supply to the headlights so that you dont run out on the screen Quote Link to comment Share on other sites More sharing options...
Toon Chris Posted January 14, 2009 Share Posted January 14, 2009 Darren-B said: The main water tank is split, when the level drops down low it stops the supply to the headlights so that you dont run out on the screen What a good idea I thought my headlight washers were getting a bit intermittent, too Quote Link to comment Share on other sites More sharing options...
Z-monster Posted December 27, 2012 Share Posted December 27, 2012 On 13/01/2009 at 13:52, RICHIERICH said: Hi Guys, Recently my headlight washers have stopped working, from the button aswell as windscreen. I thought it might be cold temp. So I checked fuse that was good so thought it might be relay? I thought i'd top my windscreen wash up as it was low, after that they worked, off windscreen wash and on demand from button. I would have a good guess that there is a level sensor in bottle, to save for windscreen when low. You may or may not of known this, regards Richard. Few pics to show where fuse/relay is located for headlight washers just incase the fuse has ruptured. You will need to remove trim around battery to expose the fuse box Any chance you can repost the pictures? Thanks! Quote Link to comment Share on other sites More sharing options...
samsniss350z Posted January 21, 2013 Share Posted January 21, 2013 Have you emptied the water tank and turned on the windscreen wipers as though washing the screen? If you get a humming noise then the motor is not at fault and it could be something as simple as crap and crud blocking up the hosing. If its not ths then i would suggest its time to break out the test meter and find out just what is recieving power and what isn't. Quote Link to comment Share on other sites More sharing options...
