Andy Posted January 12, 2009 Share Posted January 12, 2009 My Z has been off the road for the last 10 odd months so I am wondering what peoples opinions are of what I should do with it when I get it back as far as servicing goes. I did an oil change on it just before it went in but the oil has barley moved in these last 10 months. Will the 'new' oil still be ok or should I do a change as soon as I get it back on the road? What about plugs etc? Anything I should look out for? I have a feeling my battery might be shot but that's not a massive issue. Thanks Quote Link to comment Share on other sites More sharing options...
H5 Posted January 12, 2009 Share Posted January 12, 2009 Has it been started at all in the last 10 months? With the temperature movements there's always a chance there is a small amount of condensation in the fluids if it hasn't got up to temperature. With all the work you've had done (it is going to be a GTR when it comes back isn't it? ) I would give it the once over servicing wise. Quote Link to comment Share on other sites More sharing options...
Andy Posted January 12, 2009 Author Share Posted January 12, 2009 Has it been started at all in the last 10 months? With the temperature movements there's always a chance there is a small amount of condensation in the fluids if it hasn't got up to temperature. With all the work you've had done (it is going to be a GTR when it comes back isn't it? ) I would give it the once over servicing wise. It's been jumped to move it from one side of the workshop to the other and that's about it! Probably started half a dozen times if that and not for any prolonged period of time. I was aiming for a GTR'esk' car but aiming for the V-Spec now Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted January 12, 2009 Share Posted January 12, 2009 i had a car on sorn for a while, the major area to check is the brakes. amke sure the calipers haven't seized, engine wise it should be fine, as soon as you start it up ity will re oil all the parts. and all the moving bits that need oil are already dat in it. so there wont be any unlubed metal on metal action. Quote Link to comment Share on other sites More sharing options...
Andy Posted January 12, 2009 Author Share Posted January 12, 2009 Good suggestion. I have some new front discs and pads waiting to go on so I can check the calipers then Quote Link to comment Share on other sites More sharing options...
Darren-B Posted January 12, 2009 Share Posted January 12, 2009 If you taking the calipers off the disc to check, be careful as it is quite easy to pop the pistons out if theres nothing for them to clamp to, then you will have a problem, speaking from expeirence:blush: Quote Link to comment Share on other sites More sharing options...
Chris`I Posted January 12, 2009 Share Posted January 12, 2009 I would do an oil change to be on the safe side. Its pretty quick and easy. Battery will probably be gone too, but thats easy to do again if its shot. I think I once heard that petrol degrades over time too? I know on motorbikes I've read to drain the tank as much as possible before storage and stick some new fuel in when you get it out again? Dont know if the same applies to cars? Might be worth having a billy can of petrol ready just in case Quote Link to comment Share on other sites More sharing options...
Andy Posted January 12, 2009 Author Share Posted January 12, 2009 I would do an oil change to be on the safe side. Its pretty quick and easy. Battery will probably be gone too, but thats easy to do again if its shot. I think I once heard that petrol degrades over time too? I know on motorbikes I've read to drain the tank as much as possible before storage and stick some new fuel in when you get it out again? Dont know if the same applies to cars? Might be worth having a billy can of petrol ready just in case I had heard this too and the car is pretty much empty as it is at the moment so I am thinking a full tank of V-Power first thing and it should be happy. I am thinking the oil change is going to be have to be done, better to be safe then sorry I suppose, just seems a waste of the last oil! Suppose I could always drain it and use it in my runabout What about belts, plugs etc? Quote Link to comment Share on other sites More sharing options...
dcash5 Posted January 12, 2009 Share Posted January 12, 2009 Personally I would change the fluids, things like the plugs shoudnt be affected. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted January 12, 2009 Share Posted January 12, 2009 Also consider when the brake fluid was last changed. Again I *think* its meant to be every 2 years according to Nissan. Or just get a big brake kit done while its in the garage Quote Link to comment Share on other sites More sharing options...
M350ZB Posted January 13, 2009 Share Posted January 13, 2009 Not long now then Andy Quote Link to comment Share on other sites More sharing options...
Andy Posted January 13, 2009 Author Share Posted January 13, 2009 Also consider when the brake fluid was last changed. Again I *think* its meant to be every 2 years according to Nissan. Or just get a big brake kit done while its in the garage I have very little will power as it is so don't tempt me! Not long now then Andy Who knows Quote Link to comment Share on other sites More sharing options...
M350ZB Posted January 13, 2009 Share Posted January 13, 2009 Love it Andy Quote Link to comment Share on other sites More sharing options...
Chris`I Posted January 13, 2009 Share Posted January 13, 2009 Also consider when the brake fluid was last changed. Again I *think* its meant to be every 2 years according to Nissan. Or just get a big brake kit done while its in the garage I have very little will power as it is so don't tempt me! Well if you're upping the game to a GTR you're going to need GTR brakes Quote Link to comment Share on other sites More sharing options...
Andy Posted January 13, 2009 Author Share Posted January 13, 2009 Also consider when the brake fluid was last changed. Again I *think* its meant to be every 2 years according to Nissan. Or just get a big brake kit done while its in the garage I have very little will power as it is so don't tempt me! Well if you're upping the game to a GTR you're going to need GTR brakes Quote Link to comment Share on other sites More sharing options...
