RICHIERICH Posted January 11, 2009 Share Posted January 11, 2009 Hi Every1, Does any1 know what fuses are under the bonnet? Im after locating ''Headlight Washer'' Fuse as mine have stopped working due to cold temperatures. Ive checked Fuses under foot well, doesn't live there. Many Thanks Regards Richard. Quote Link to comment Share on other sites More sharing options...
dcash5 Posted January 11, 2009 Share Posted January 11, 2009 There are two fuse boxes in the engine bay one next to the battery, clearly visable when you remove the battery cover. the second is located behind the battery and you need to take the covers surrounding the battery off. All the fuses are written on the covers. I cant locate it for you as I dont have headlight washers Quote Link to comment Share on other sites More sharing options...
M13KYF Posted January 12, 2009 Share Posted January 12, 2009 moved Quote Link to comment Share on other sites More sharing options...
RICHIERICH Posted January 12, 2009 Author Share Posted January 12, 2009 Right ok cheers, the fuses in front of battery are not labelled on the lid but thanx I will have a look for fuses behind battery. Quote Link to comment Share on other sites More sharing options...
