Martin W Posted January 8, 2009 Share Posted January 8, 2009 can anyone educate me as to how these things work? Anyone got one installed? Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted January 8, 2009 Share Posted January 8, 2009 Got one on but not plumbed in yet! Ian has one fitted.. An oil catch can will "catch" the oil vapor that is released through your PCV system and condense the vapor in the can so that you don't recirculate nasty oil sludge back into your intake tract. Quote Link to comment Share on other sites More sharing options...
clarkie34 Posted January 8, 2009 Share Posted January 8, 2009 Where do you get these from. Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted January 8, 2009 Share Posted January 8, 2009 I'm sure I've got this in stock, took a photo of it 2 weeks ago, will check tomorrow... Quote Link to comment Share on other sites More sharing options...
Martin W Posted January 8, 2009 Author Share Posted January 8, 2009 Got one on but not plumbed in yet! Ian has one fitted.. An oil catch can will "catch" the oil vapor that is released through your PCV system and condense the vapor in the can so that you don't recirculate nasty oil sludge back into your intake tract. Been 'Wiki' reading - so where does the sludge go? Quote Link to comment Share on other sites More sharing options...
T2 Posted January 8, 2009 Share Posted January 8, 2009 How much is the oil catch tank pictured above ? Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted January 8, 2009 Share Posted January 8, 2009 If you have taken your plenum off you will see the sludge! I have the 5zigen one fitted but needs plumbing in... Issue is that the 5zigen is sold as a 350z / universal part... Kev at Envy was speaking to them so they could provide the right size hose and bracket for the kit... Its at the front There is a lovely ARC one that has has an extra tube that fits into another part of the system Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted January 8, 2009 Share Posted January 8, 2009 How much is the oil catch tank pictured above ? It's £49.99 plus delivery... Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted January 8, 2009 Share Posted January 8, 2009 One thing is that the plastic hoses even though re-enforced can twist and kink, so best to get some metal sleved tube. also the fittings are tight under the engine cover so depending on where you put the can you may need some 180 and 90 degree bends.... Also the tubes will go brown with the oil so the silicon or braided hoses will look cleaner! Quote Link to comment Share on other sites More sharing options...
Martin W Posted January 8, 2009 Author Share Posted January 8, 2009 If you have taken your plenum off you will see the sludge! I have the 5zigen one fitted but needs plumbing in... Issue is that the 5zigen is sold as a 350z / universal part... Kev at Envy was speaking to them so they could provide the right size hose and bracket for the kit... Its at the front There is a lovely ARC one that has has an extra tube that fits into another part of the system Its the ARC one that started this thread.... Quote Link to comment Share on other sites More sharing options...
Ian Posted January 8, 2009 Share Posted January 8, 2009 This is mine. i went for the universal 9mm Cusco can & used samco hose instead of the clear one that came with it (Cusco can only comes with 1m hose & you will need 2m) I also have 2m of blue samco hose for sale which will fit with a 9mm can Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted January 8, 2009 Share Posted January 8, 2009 Quote Link to comment Share on other sites More sharing options...
Ian Posted January 8, 2009 Share Posted January 8, 2009 I need that ARC can Quote Link to comment Share on other sites More sharing options...
Martin W Posted January 8, 2009 Author Share Posted January 8, 2009 I need that ARC can and when you roll her on her back ... Quote Link to comment Share on other sites More sharing options...
clarkie34 Posted January 8, 2009 Share Posted January 8, 2009 Where do you get those from. Also noticed in the pics some of the bolts have been replaced round the engine bay,where can I get these from. Quote Link to comment Share on other sites More sharing options...
Ian Posted January 8, 2009 Share Posted January 8, 2009 Cusco can was from rhdjapan, bolts from mynismo.com Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted January 8, 2009 Share Posted January 8, 2009 If you want the arc can its gonna cost you about £215... Yep bolts are gallery bolts from mynismo as Ian said... If your buying get together with someone else as the P+P to the uk is the same for one as it is 2.... Quote Link to comment Share on other sites More sharing options...
clarkie34 Posted January 8, 2009 Share Posted January 8, 2009 Thanks guys. Why is the ARC so expensive. Quote Link to comment Share on other sites More sharing options...
M350ZB Posted January 9, 2009 Share Posted January 9, 2009 This is mine. i went for the universal 9mm Cusco can & used samco hose instead of the clear one that came with it (Cusco can only comes with 1m hose & you will need 2m) I also have 2m of blue samco hose for sale which will fit with a 9mm can Looks quality mate, expect a few PM's Quote Link to comment Share on other sites More sharing options...
dcash5 Posted January 9, 2009 Share Posted January 9, 2009 Have your strut brace bolts rusted though? Quote Link to comment Share on other sites More sharing options...
mec Posted January 9, 2009 Share Posted January 9, 2009 Does it do much, mpg, power? Quote Link to comment Share on other sites More sharing options...
Ian Posted January 9, 2009 Share Posted January 9, 2009 Have your strut brace bolts rusted though? They have a bit, hopefully I can clean them up a bit though. The bonnet vents are right over the bolts so they take a lot of water on Does it do much, mpg, power? MPG increased to 50mpg & gained an extra 75bhp Quote Link to comment Share on other sites More sharing options...
mec Posted January 9, 2009 Share Posted January 9, 2009 Does it do much, mpg, power? MPG increased to 50mpg & gained an extra 75bhp wow 75bhp across the rev range? Quote Link to comment Share on other sites More sharing options...
Martin W Posted January 9, 2009 Author Share Posted January 9, 2009 Any idea on servicing. I presume they have clear tube's for inspection. How long between removal and flushing out? any filter inside? Quote Link to comment Share on other sites More sharing options...
Kevo Posted January 9, 2009 Share Posted January 9, 2009 Just looking around the web and stumbled on this. http://www.pbase.com/rsrock/oil_catch_can Do you think this would be (nearly) as effective as a proper unit? Quote Link to comment Share on other sites More sharing options...
