TDI Posted May 8, 2006 Share Posted May 8, 2006 Hi there, Has anyone used the Procharger with higher than the recommended boost pressure? We have a customer that has one installed who wants the engine/ecu/fuelling etc upgraded but also wants to raise the boost pressure from around 7psi up to 15 psi. I'm concerned about the supercharger reliability Any information or experiences will be much appreciated. Thanks in advance Mark Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted May 8, 2006 Share Posted May 8, 2006 You should advise him to search on my350z.com Certainly the anecdotal evidence is that ATi's Procharger is the least reliable FI solution in terms of blowing Z and G motors. This used to be GReddy TT way back when. [Edit -> That was unfair, the issue was that you could not add timing retard with ATi out-the-box so provided you add some solution to do that e.g. J&S Safeguard or better yet, UTEC, there is no real reason why this should be still true - sorry it was the same timing issue with GReddy and was really down to people not knowing the kits well enough in the early days] If the guy starts from here http://www.my350z.com/forum/showthread. ... 45&page=16 you can see only 1 seems to be running at those boost levels (on a built motor) This should reveal some useful stuff http://www.my350z.com/forum/search.php? ... =40&page=6 Quote Link to comment Share on other sites More sharing options...
Removed Posted May 8, 2006 Share Posted May 8, 2006 the fact that it's also the least used SC solution also must count for something Quote Link to comment Share on other sites More sharing options...
TDI Posted May 9, 2006 Author Share Posted May 9, 2006 Interesting stuff. Thanks Guys Quote Link to comment Share on other sites More sharing options...
Revsport Posted May 9, 2006 Share Posted May 9, 2006 I think the problem with the Procharger kit is the managment it used J&E safe guard. It is a realy bad system for the 350z better with a unichip or something similar. Quote Link to comment Share on other sites More sharing options...
TDI Posted May 10, 2006 Author Share Posted May 10, 2006 I think the problem with the Procharger kit is the managment it used J&E safe guard. It is a realy bad system for the 350z better with a unichip or something similar. Thank you very much for that - much appreciated . Anything like that we can take care of, what I was mostly concerned about was the superchargers reliability at higher boost pressures. Procharger (ATI) say that it will be fine, but I prefer to place realism before optimism Quote Link to comment Share on other sites More sharing options...
