ads120584 Posted December 30, 2008 Share Posted December 30, 2008 I have tried to search for this all over and cant find it.... I did a bit of work today, changed plenum spacer etc etc and forgot to plug the maff sensor back in before i started it back up so it brought the light on, ive tried doing the pedal resetting thingy and all its doin is winding me up haha How else can i do it or is the any one in the blackpool area that can for a small fee Thanks Ads Quote Link to comment Share on other sites More sharing options...
martinmac Posted December 30, 2008 Share Posted December 30, 2008 It has to be done very precisely and can take a few tries. May be down your way at the weekend though if its not sorted Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted December 30, 2008 Share Posted December 30, 2008 http://www.350z-uk.com/forum/viewtopic.php?t=89 you could try disconnecting the battery for 30 mins so that it loses the stored codes Quote Link to comment Share on other sites More sharing options...
ads120584 Posted December 30, 2008 Author Share Posted December 30, 2008 cheers Martinmac, ill give it another go tomoor if not ill give you a pm Cheers again ppl Ads Quote Link to comment Share on other sites More sharing options...
Stew Posted December 30, 2008 Share Posted December 30, 2008 I work through the procedure and never have too much of a problem. Try it with a watch (accurate timing) and also try to do 1 elephant 2 elephant counting. Another trick it to continue counting instead of doing everything for 5 secs, 10 secs etc keep a running total. Most have found this makes t far more accurate. Quote Link to comment Share on other sites More sharing options...
ads120584 Posted December 31, 2008 Author Share Posted December 31, 2008 cheer Stew, ill try that Ads Quote Link to comment Share on other sites More sharing options...
