Add an MP3 player to the Bose - but then a wiring disaster!
Toon Chris
Need some help here guys... :cry:
After an carefully engineered iRiver Xmas pressie :) I have used the holiday break to take out the console and add a MP3 cable to the Bose.
I followed the excellent guide on my350z.com (shoudl be a sticky on here, maybe?) :thumbs:
http://my350z.com/forum/4292171-post98.html
I also do the trick with to prevent a tape needing to be inserted.
http://my350z.com/forum/4764747-post103.html
Everything went very well except the *BIG* problem! The main wiring plug (the largest of the three connectors) into the back of the Bose exploded apart on refitting. The Bose is a warranty replacement so I guess the monkey that fitted it broke the plug.
Although I can put it back together again I don't know which wire goes in which hole! The colours of the wires is not clear in the guide and in any case seem to be different to mine.
Has anyone got a good picture of the wires going into the back of a UK Bose (my Z is an 04 if it matters)? Failing that, can anyone tell me which colour wire goes in which hole in the plug! :surrender:
Success, sort of.
Putting the block back together meant that some wires touched each other - it was unavoidable really. The result was a blown fuse which I located in a block by the battery and replaced. There is another fuse blown somewhere which controls the power to the radio and the power to the instrument panel and digital pod (or two fuses?). I have crawled all over the car with a torch but can't find them - only a fuse block near the drivers feet but they are all intact.
I have seen a thread which talks of a fabled 3rd fuse, but where is it?
Oh yes, and by the way, my tape button doesn't *click* like the CD and Radio buttons, is this normal or is it broken? It doesn't seem to be depressed any further than the other two?
CD auto-changer (built into audio unit) operation is controlled by audio unit.
Power is supplied at all times
through 15A fuse [No. 37, located in the fuse and fusible link box]
to audio unit terminal 6,
to BOSE speaker amp. terminal 11, and
to option connector for satellite radio receiver terminal 1.
through 15A fuse [No. 17, located in the fuse block (J/B)]
to woofer amp. terminal 8.
With the ignition switch in the ACC or ON position, power is supplied
through 10A fuse [No. 6, located in the fuse block (J/B)]
to audio unit terminal 10, and
to option connector for satellite radio receiver terminal 6.
through audio unit terminal 12
to BOSE speaker amp. terminal 41,
through BOSE speaker amp. terminal 32
to woofer amp. terminal 6, and
Ground is supplied through the case of the audio unit.
this is by the battery chris ---Power is supplied at all times
