radiator fans (help)
AUTO EXPRESS
please help radiator fans not cutting in. have checked fuses ok.engine is overheating in traffic. is the radiator fan switch fitted on the drivers side of the radiator?
has anybody changed switch?
Model dependant there is generally no fan switch fitted to the radiator.
Your problem will probably be electrical.
There are 3 coolant fan relays, have you checked them ?
Also, check for continuity, short to ground and short to power.
If you do not have a meter or lacking in know how then simply unplug the 4 harness connectors at and around the fan area and make good connections, especially the earth.
And also run a separate power and earth to the fans to check fan operation but it is highly unlikely that you will have a fan failure.
Alex.
