T2 Posted December 13, 2008 Share Posted December 13, 2008 What do you think for the money worth a try or not http://cgi.ebay.co.uk/NISSAN-350Z-3-5-E ... 240%3A1318 Quote Link to comment Share on other sites More sharing options...
IanS16 Posted December 13, 2008 Share Posted December 13, 2008 I wouldn't want to strap a £15 item to my ECU. I would be interested to see if it works though, especially as the main problem with tuning a Zed is the restriction of airflow by the ECU. Quote Link to comment Share on other sites More sharing options...
Lexx Posted December 13, 2008 Share Posted December 13, 2008 How to knacker your motor in 3 easy steps.... remember, anything that looks too good to be true, normally is. Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted December 13, 2008 Share Posted December 13, 2008 these things are normally a cheap resistor which alters the signal from the maf to the ecu, giving a false reading for either airflow or air temp 99% of the time they dont do a lot, worst case scenario, long term, they can cause the ecu to overfuel causing pinking or under fuel causing the valves to burn out Quote Link to comment Share on other sites More sharing options...
Chris`I Posted December 13, 2008 Share Posted December 13, 2008 these things are normally a cheap resistor which alters the signal from the maf to the ecu, giving a false reading for either airflow or air temp 99% of the time they dont do a lot, worst case scenario, long term, they can cause the ecu to overfuel causing pinking or under fuel causing the valves to burn out Yup, this one says it alters the air temp reading. Probably telling it its nice and cold and so fuels more to try and increase power. If you want, go for it, but I wouldnt let some £15 chip feck about with my fuel mixture! Thats what a decent tuner and piggy back ECU are for. There is a reason they cost so much!!! Quote Link to comment Share on other sites More sharing options...
T2 Posted December 13, 2008 Author Share Posted December 13, 2008 Yeh does what is says on the tin Not something I would use myself but I was talking more about the wild BHP claims Quote Link to comment Share on other sites More sharing options...
Stew Posted December 14, 2008 Share Posted December 14, 2008 Recomended by MAx Power...... enough said! :lol: Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted December 14, 2008 Share Posted December 14, 2008 Definately belongs to the the fury dice brigade Quote Link to comment Share on other sites More sharing options...
