Changing Rear Bulbs
Martin W
I'm obviously not cut out for this.
I set out today to
1) Change my 04 Stop/Tail for a T20 LED
2) Change the Indicators for the SIlvatec Chrome indicators that a lot of you use
Rear lights off - no problem - even in the teeming rain. :yuck:
I followed the instructions in the guide section on here to find that there is no way I could get my arm far enough down to change the Indicators.
And I can't work out how to get the Stop/Tail light out of the housing for fear of breaking something. :scare: Any ideas anyone?
??? what rear lights have you taken off ? the stop/tail lights are the rear lights you take off and reach down through the hole to access the indicators
Brake lights removed, reach down and turn the bulb, its a bit tight but i did mine that way, use wife/girlfriend/mums arms if they are thinner :blush:
I think my arm would end up staying there if I pushed hard enough to reach it.
:surrender:
What about removing the brakelight? is it just a very firm twist? or a bit of leverage somewhere?
I'm trying to change both Stop/Tail - for an LED equivalent I got from OZ.
(Trying to work out how to remove the light grey 'plug' from the back of the light unit
AND
Swap the indicators out too
:surrender:
just pull mate, iirc you stand at the side of the quarter panel and pull towards you, there are lugs on the opposite side to the 3 bolts you have undone, theres a gasket on them that sticks a bit :thumbs:
So you have to take the rear clusters out to change the indicators.
Yup. Its easy though, only 3 bolts on each side along the top of the light :thumbs:
To remove the connectors turn them 1/4-1/2 turn and it should just come out.
Assuming you used my guide, I cant see how you can get it wrong :surrender:
http://www.350z-uk.com/forum/viewtopic ... indicators
sounds like he had problems getting the cables out of the brake light chris, they are tight :thumbs:
Yep - thought they were glued in at first :blush: - replaced now tho :thumbs:
led's look B) and make the car look newer :thumbs:
