Martin W Posted November 30, 2008 Share Posted November 30, 2008 Anyone tell me what an "organic" clutch is. I'm planning ahead for the next year at the moment and an uprated Clutch/Flywheel is something I think I should be doing. Been looking at Envy's ads on ebay. http://www.envyperformance.com/images/n ... Clutch.jpg Quote Link to comment Share on other sites More sharing options...
Pingu2 Posted November 30, 2008 Share Posted November 30, 2008 it means the clutch material is organic based - rather than being ceramic or metallic. I think generally that organic clutches do not handle heat as well as ceramic ones, but they are easier to drive and less wearing. see: http://www.subydude.com/osc/detailsdoc.php?3065 Quote Link to comment Share on other sites More sharing options...
bigphil Posted December 1, 2008 Share Posted December 1, 2008 Anyone tell me what an "organic" clutch is. I'm planning ahead for the next year at the moment and an uprated Clutch/Flywheel is something I think I should be doing. Been looking at Envy's ads on ebay. http://www.envyperformance.com/images/n ... Clutch.jpg Same part numbers as the standard Exedy unit at £250 Quote Link to comment Share on other sites More sharing options...
Martin W Posted December 1, 2008 Author Share Posted December 1, 2008 Anyone tell me what an "organic" clutch is. I'm planning ahead for the next year at the moment and an uprated Clutch/Flywheel is something I think I should be doing. Been looking at Envy's ads on ebay. http://www.envyperformance.com/images/n ... Clutch.jpg Same part numbers as the standard Exedy unit at £250 Phil (Andrew?) - would you recommend doing flywheel at same time? - if so which would you give best recommendation? Quote Link to comment Share on other sites More sharing options...
Chris`I Posted December 1, 2008 Share Posted December 1, 2008 Anyone tell me what an "organic" clutch is. I'm planning ahead for the next year at the moment and an uprated Clutch/Flywheel is something I think I should be doing. Been looking at Envy's ads on ebay. http://www.envyperformance.com/images/n ... Clutch.jpg Same part numbers as the standard Exedy unit at £250 Phil (Andrew?) - would you recommend doing flywheel at same time? - if so which would you give best recommendation? Most poeple do. By the time you have paid for the labour its not much more to get it done and makes a considerable difference to every day driving Quote Link to comment Share on other sites More sharing options...
Martin W Posted December 1, 2008 Author Share Posted December 1, 2008 it means the clutch material is organic based - rather than being ceramic or metallic. I think generally that organic clutches do not handle heat as well as ceramic ones, but they are easier to drive and less wearing. see: http://www.subydude.com/osc/detailsdoc.php?3065 thanks for that - learning more day by day!! Quote Link to comment Share on other sites More sharing options...
bigphil Posted December 1, 2008 Share Posted December 1, 2008 it means the clutch material is organic based - rather than being ceramic or metallic. I think generally that organic clutches do not handle heat as well as ceramic ones, but they are easier to drive and less wearing. see: http://www.subydude.com/osc/detailsdoc.php?3065 thanks for that - learning more day by day!! JWT flywheel does make a difference to how the car responds and increases engine braking. £315 Quote Link to comment Share on other sites More sharing options...
