Rear top ball joint ?
Zummertor
Doing the regular check over and noticed a little play in the rear left wheel when jiggling (guess you can accept that as a technical term).
I had no one else around but thought I saw a little movement in the upper ball joint.
Any opinions / thoughts on what I should check and options this might open up ?
My imagination is a bit vivid so best no to there ;)
Gone cold and dark now but will check again in the morning, I thought no drone as was guessing bearings first then certain movement in wheel but not a real noise to go with it. Will try again in the morning with better light and the chance of someone else to look from other side or v.v.
If bearing I'd have expected a sound but nothing specific(getting old might not help) not a lot of play but enough to be not normal.
Will go play again but noticeably different for other rear (leaving an opening here ;) )
If not bearings is there any likely replacement of a part e.g. ball joint / droplink that would warrant thinking about a little change ?
