Eibach Spacers From Cougar Store 350z 370z
MITZ@CougarStore
  • Replies 85
  • Created
  • Last Reply
Top Posters In This Topic
All, I’ve got 4 more full sets arriving this week, 2 have already been accounted for, so I still have 2 full sets available.
If you’re interested then please do drop me a PM… :)
Many thanks,
:thumbs:
All, I forgot to update this thread on Friday but these are now in stock, 2 sets available, ready to be sent out… :)
Many thanks,
:thumbs:
Got my spacers yesturday from CS, very quick delivery :thumbs:
looking forward to putting them on, just waiting for the wheather to improve
Make sure you use locktight on the nuts holding the spacers on.
Tell me more... :)
Tell me more... :)
Just that within a day or two of fitting mine, I started to get a noise from one of the front wheels that sounded like a wheel bearing breaking up. On closer inspection I noticed that the nuts holding the spacer onto the hub had started to work loose so I applied some locktight and torqued them up tight and then repeated the process for the remaining 3 wheels and haven't had a problem since.
Tell me more... :)
Thats good to know :thumbs:
red or blue ? ;)
it would be good if someone could give a torque setting for these :thumbs:
Tell me more... :)
No different to fitting new wheels with new nuts really - need to check after a few days but rather more fiddly to do. Demon Tweeks did my spacers up so tight my local garage struggled to get them off...
Tell me more... :)
that makes a change, i know a few people who have bike tyres fitted there only to find the wheel has come lose 5 miles down the road :headhurt: i had to help one guy on an r6, he didnt even get off the ind estate
red or blue ? ;)
Blue and I cracked then up to 75 ft lb :)
red or blue ? ;)
good info rev :thumbs:
Quick update, I’ve got 4 sets of 20mm Eibach spacers in stock. This is the best fitment for owners who have either the standard alloys or the RAYs.
In addition to the above, I’ve also got the following available for our Zeds…
1 set of 5mm spacers
1 set of 15mm spacers
2 sets of 25mm spacers
Many thanks,
:thumbs:
PS: Photos of the 20mm spacers can be seen on page 2 of this thread.
Many thanks,
:thumbs:
I thought 25mm on the back of mine was perfect. :teeth:
Many thanks,
:thumbs:
Digsy, am I right in reading in a previous thread that you had 15mm on the front… :thumbs:
Tell me more... :)
I thought they just bolted on using your existing nuts :wacko: i surpose you bolt them to the existing disc and your wheel then will only bolt on to the spacer and not the disc ?? It would worry me they could come off though, hence the lock tite. :)
Many thanks,
:thumbs:
That's right but the 15mm wasn't enough IMHO. I think a 20mm front and 25mm rear would be perfect. I think this is what Chesterfield now has. :)
Tell me more... :)
They come with new nuts that are designed to sit flush inside the spacer and it's these that you need to use locktight on. :thumbs:
