lnorange Posted November 1, 2008 Share Posted November 1, 2008 Hi Had my first 350z for a few weeks now and what fun. Top car with no modern bells and whistles just power. Slight problem with the drivers side roof during the heavy rain this week as I have a slight leak at the top where the passenger window meets the door rubber. Water is slowly seeping in and a few dribs are on the inside of the door and run onto the carpet. It looks like the rubber is just not tight enough against the window. can anyone help with this one ??? Is the a common fault? New rubber door seal needed. Car is a 350z 05 plate roadster. Thanks (in advance)!! Les Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted November 1, 2008 Share Posted November 1, 2008 My Roadster leaks all over the place ....one of the joys:yahoo: Seriously tho' if this is really bothering you then pull off the rubber seal from the body and put a packing in so that the seal is pushed closer to the glass and problem solved :yahoo: A few layers of tape would do the job;) Quote Link to comment Share on other sites More sharing options...
Sunny1 Posted November 1, 2008 Share Posted November 1, 2008 Hi what i am about to write may not be applicable to your problem, but i have owned a toyota mr2 T-bar from new for 16 years (now a proud owner of a zed roadster as well) i had a similar problem with water seeping through the seal about 5 years ago now, i was advised to remove the door panel and adjust the window upwards, the window frame was on slots which allowed the glass to move in return created a tighter seal and i have never looked back, i dont know if this helps but maybe someone can tell you if the same principal applies. Quote Link to comment Share on other sites More sharing options...
Ekona Posted November 1, 2008 Share Posted November 1, 2008 Could be worth putting some grease along the rubber as well to lubricate it a bit, in case it's dried out a touch. Quote Link to comment Share on other sites More sharing options...
lnorange Posted November 2, 2008 Author Share Posted November 2, 2008 hi, thanks for the suggestions,going to try the easy ones first tape and grease! Found the guide on how to get the inner door skin off, anyone know if adjustments can be made? Quote Link to comment Share on other sites More sharing options...
steve3000 Posted November 3, 2008 Share Posted November 3, 2008 Just a thought, but is your window closing properly when you shut the door? On the coupe the window drops/raises when you open/close the door and this didn't work properly on mine when i bought it & leaked both sides. Had it fixed under warentee but only took the guy 2 minutes (I think he just reset the mechanism???). Steve Quote Link to comment Share on other sites More sharing options...
lnorange Posted November 3, 2008 Author Share Posted November 3, 2008 Window working fine, steps down and up with no problems. grease now in place with tape as suggested Quote Link to comment Share on other sites More sharing options...
stanski Posted November 6, 2008 Share Posted November 6, 2008 Had the same issue - the window was a smidge too low when closed and did'nt make enough of a seal with the rubber - you need to either do the reset procedure from the forum or get the window moved a fraction - higher - since m8ine was done its not leaked since (thank goodness!) Quote Link to comment Share on other sites More sharing options...
lnorange Posted November 7, 2008 Author Share Posted November 7, 2008 Window leak now fixed, grease and a little packing worked well. Thanks Quote Link to comment Share on other sites More sharing options...
03ZWeapon Posted October 15, 2023 Share Posted October 15, 2023 Butyl Tape Quote Link to comment Share on other sites More sharing options...
