Engine oil...
Adriank
Sorry to post this its probably been asked before, but im getting the oil / filter done, what oil do people use in their cars?
I need to buy the oil tommorow, so is nissan best bet or any other places i can buy it? How much does it use 5 litres enough?
Thanks in advance
Adrian
I I think its 5w-30
Correct :thumbs: Though i use Amsoil :)
Silkolene PRO S 5W-40 FROM OPIEOILS
fast delivery :thumbs: i changed mine today, i was tempted to try a different filter but stayed with an oem one in the end :thumbs:
hole in the engine undertray to access the drain bolt and filter
i used to use the silkolene pro S from oilman on my old Integra, but the guy i get my servicing done with uses castrol edge 10-60 in everything, as its what his race cars run.
Should i avoid that oilin the 350, or would it be ok still? I'm going to have a look round locally and see what i can find in 5-30, but most are in 4l tubs so going to have to get a 4ltr and a 1ltr :-(
Do you have any idea on oil temps? The Castrol RS is now known as the Castrol Edge Sport here http//www.opieoils.co.uk
To be honest you can do much better, take a look at the ester based oils of the Silkolene Pro S and the Motul 300v. These are proper performance synthetics.
Cheers
Guy.
FROM OPIE .........
Cheers
Guy.
FROM OPIE .........
Dont forget the synthetic Amsoil from Opie too ;)
Cheers
Guy.
FROM OPIE .........
:thumbs:
