door window system
Appo
Hi
My driver door window has adopted a mind of its own. Sometimes it works ok, sometimes it refuses to work at all and sometimes it has a fit - goes up and down like a lunatic until I press the switch again. :rant:
I suspect it is the power window regulator which is faulty, not the motor or main switch, because when the system decides to work these both do what they should.
Anyone got any thoughts on this?
I suspect that if I get the door trim off, then replacing the regulator should be a doddle - is that so?
Thanks
Appo
