Gaz Walker Posted September 4, 2008 Share Posted September 4, 2008 As a few of you have already seen at JAE I have made a new addition to the Engine bay bling department. After realising I had no chance of fitting this part with the Cusco Strut Brace I had to ditch this item in favour of a carbon GT-Spec brace. The part was of the usual high 5Zigen quality and was pretty simple to fit once the strut brace design had been changed. The part was designed to fit with the standard brace and was not designed to be used with a plenum spacer so did require a few tweaks to make it fit perfectly. The engine damper is said to reduce engine vibration and helps reduce the stress on your engine mounts. Can't really quantify this but it does look amazing! 5Zigen Damper: Thanks Kevin Quote Link to comment Share on other sites More sharing options...
Stew Posted September 4, 2008 Share Posted September 4, 2008 Yummy! Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted September 4, 2008 Share Posted September 4, 2008 very Quote Link to comment Share on other sites More sharing options...
Ian Posted September 4, 2008 Share Posted September 4, 2008 Where did you get the carbon bits around the battery covers? & the silver covers for the leads? Quote Link to comment Share on other sites More sharing options...
drewbie Posted September 4, 2008 Share Posted September 4, 2008 Truly Awesome Quote Link to comment Share on other sites More sharing options...
sunset350z Posted September 4, 2008 Share Posted September 4, 2008 Looks really nice, how much are they? i want one. Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted September 4, 2008 Share Posted September 4, 2008 Where did you get the carbon bits around the battery covers? & the silver covers for the leads? Carbon bits are Water Transfer Printing onto the stock plastic covers. Silver lead covers are the 5zigen Pro Racer Harness (Grounding Kit) But I do know if somewhere you can get some to go over the spills kit.... You may get an additional pressie when the package is winging its way if you want Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted September 4, 2008 Share Posted September 4, 2008 Where did you get the carbon bits around the battery covers? & the silver covers for the leads? Carbon bits are Water Transfer Printing onto the stock plastic covers. Silver lead covers are the 5zigen Pro Racer Harness (Grounding Kit) But I do know if somewhere you can get some to go over the spills kit.... You may get an additional pressie when the package is winging its way if you want Mark i think he means the coiled silver cable covers not the gounding kit Quote Link to comment Share on other sites More sharing options...
Ian Posted September 4, 2008 Share Posted September 4, 2008 Where did you get the carbon bits around the battery covers? & the silver covers for the leads? Carbon bits are Water Transfer Printing onto the stock plastic covers. Silver lead covers are the 5zigen Pro Racer Harness (Grounding Kit) But I do know if somewhere you can get some to go over the spills kit.... You may get an additional pressie when the package is winging its way if you want Mark i think he means the coiled silver cable covers not the gounding kit Yup meant the coiled cables, additional pressie sounds like an idea though Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted September 4, 2008 Share Posted September 4, 2008 Where did you get the carbon bits around the battery covers? & the silver covers for the leads? Carbon bits are Water Transfer Printing onto the stock plastic covers. Silver lead covers are the 5zigen Pro Racer Harness (Grounding Kit) But I do know if somewhere you can get some to go over the spills kit.... You may get an additional pressie when the package is winging its way if you want Mark i think he means the coiled silver cable covers not the gounding kit These? Quote Link to comment Share on other sites More sharing options...
Ian Posted September 4, 2008 Share Posted September 4, 2008 Where did you get the carbon bits around the battery covers? & the silver covers for the leads? Carbon bits are Water Transfer Printing onto the stock plastic covers. Silver lead covers are the 5zigen Pro Racer Harness (Grounding Kit) But I do know if somewhere you can get some to go over the spills kit.... You may get an additional pressie when the package is winging its way if you want Mark i think he means the coiled silver cable covers not the gounding kit These? Yup Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted September 4, 2008 Share Posted September 4, 2008 Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted September 4, 2008 Share Posted September 4, 2008 Kev sells them, but I have some silver braid and some heat shrink you can cover your spills kit with if you want it? Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted September 5, 2008 Author Share Posted September 5, 2008 As Mark correctly says the covers have been treated with the carbon fibre transfer dip and we keep the chrome hose covers in stock. They certainly tidy up the wiring and make a feature of what is often something that is ugly and untidy in my opinion. I will have some at the national for anyone who wants to decorate there engine bay. Thanks Kevin Quote Link to comment Share on other sites More sharing options...
H5 Posted September 5, 2008 Share Posted September 5, 2008 Someone's been busy Mark! Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted September 5, 2008 Share Posted September 5, 2008 Been even busier recently!! That was about 4 weeks ago! Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted September 6, 2008 Author Share Posted September 6, 2008 We are doing them for £295. Not the cheapest bit of kit but they do look the bollocks and the quality is second to none. Thanks Kevin Looks really nice, how much are they? i want one. Quote Link to comment Share on other sites More sharing options...
Ian Posted September 6, 2008 Share Posted September 6, 2008 We are doing them for £295. Not the cheapest bit of kit but they do look the bollocks and the quality is second to none. Thanks Kevin Looks really nice, how much are they? i want one. Can you pm me a price on the hose covers Quote Link to comment Share on other sites More sharing options...
