P15UL T Posted August 24, 2008 Share Posted August 24, 2008 as above, i have never heard other wise, but it would be great if someone could confirm. thanks Paul Dream CustomZ Quote Link to comment Share on other sites More sharing options...
nixy Posted August 24, 2008 Share Posted August 24, 2008 how do you tell the difference? Quote Link to comment Share on other sites More sharing options...
P15UL T Posted August 24, 2008 Author Share Posted August 24, 2008 well, when switching the main beams on they should glow blue for a second before warming up to a bright white, also attached to the underside of the headlamp there is a powerpack although you will only be able to see this with the bumper or the headlight removed. i am just curious as i know some of the american ones come non HID any help would be great Paul Quote Link to comment Share on other sites More sharing options...
marzman Posted August 24, 2008 Share Posted August 24, 2008 I cant confirm that they are ALL hid, but a lot have hid-capability. However when they are SVA'd, the importer takes out the hid bulbs and bypasses the ballast, thus making them standard headlights. In my case they left it like that, but i've had my headlights out and the ballasts are still there - would just need to un-frig the wiring and buy some bulbs (cheapest i could find is £43ea.) Chris. Quote Link to comment Share on other sites More sharing options...
P15UL T Posted August 25, 2008 Author Share Posted August 25, 2008 the philips ones that come as standard are about £70 each, you can get some non branded ones on ebay for £30 but i would recomend buying them in pairs so they colour match Quote Link to comment Share on other sites More sharing options...
nixy Posted August 25, 2008 Share Posted August 25, 2008 mine are definitely as you describe then, and it's an import so I presume they were taken out for the SVA and then replaced. Quote Link to comment Share on other sites More sharing options...
YHTM Posted August 25, 2008 Share Posted August 25, 2008 Ive now got a permanent image of a headlight etched onto my retina as a result of staring into the lens trying to see if it starts off blue!! I think mine does but it's not that blue at first. I don't understand why the bulbs would be changed as part of the SVA, no mention was made of that when I had mine done over here. Quote Link to comment Share on other sites More sharing options...
nixy Posted August 25, 2008 Share Posted August 25, 2008 I think it's to do with the fact that we don't have headight washers which is a requirement if you have those bulbs in the UK but not a requirment for an MOT. Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted August 25, 2008 Share Posted August 25, 2008 nixy said: I think it's to do with the fact that we don't have headight washers which is a requirement if you have those bulbs in the UK but not a requirment for an MOT. +1 Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted August 25, 2008 Share Posted August 25, 2008 GIXXERUK said: nixy said: I think it's to do with the fact that we don't have headight washers which is a requirement if you have those bulbs in the UK but not a requirment for an MOT. +1 Yup IIRC the "reasoning" that you need washers for SVA is to do with alignment and scattering effect when dirty rather than any heat issue But its boll*x reasoning as it's not a requirement for MoT Quote Link to comment Share on other sites More sharing options...
YHTM Posted August 25, 2008 Share Posted August 25, 2008 The only way I am going to be able to tell is to take headlamp off which I am going to have to do anyway. I've got to remove the bumper anyway to fit different horns, is it straightforward or are there issues with airbag detectors? Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted August 25, 2008 Share Posted August 25, 2008 YHTM said: The only way I am going to be able to tell is to take headlamp off which I am going to have to do anyway. I've got to remove the bumper anyway to fit different horns, is it straightforward or are there issues with airbag detectors? Just a load of bolts, straight forward though Quote Link to comment Share on other sites More sharing options...
P15UL T Posted August 25, 2008 Author Share Posted August 25, 2008 first step is to loosen the front bumper to do this there are 6 black popper clips under the bonnet (if you have fitted a radiator cooling panel these are the clips that also hold this on) the next step is to peel back the inner wheels arch liners, you need to do these one at a time whilst having the steering locked to one way to gain access. once you have peeled back the arch liner look up and you should see 2 10mm bolts that hold the bumper onto the outer wheel arch, remove these on both sides, your bumper should now pull forward and sit onto the ground, it will still be attached to the undertray and also the washer jets for the lights. you can now gain access to the bolts that hold on the lights which are 10mm there is one inside the engine bay one attaching it to the outer wheel arch there are 2 underneath the light that you will need to use an extension piece on the socket to reach. once loose be careful when removing i so as not to scratch you paintwork. the harness is located at the back of the light and a slotted flat screwdriver is probably best to unclip the 2 parts of the harness. Paul Dream CustomZ Quote Link to comment Share on other sites More sharing options...
YHTM Posted August 26, 2008 Share Posted August 26, 2008 Right then - removed the bumper!! Wasn't too horrendous thanks to the advice received plus use of the search facility. Took the opportunity to fit upgraded horns, remove the reflectors for later replacement and use the sticky tape supplied with the Ings front spoiler I fitted recently. Below are pictures of my lights - couldn't see any sign of the HDI 'extras' so presume they were removed and not changed back unless anyone can say otherwise?? Quote Link to comment Share on other sites More sharing options...
P15UL T Posted August 26, 2008 Author Share Posted August 26, 2008 yup it seems your importer was in a good mood that day the bulbs with the bar along the side are the hid bulbs..be gentle with them it looks like they have disconected them and rewired them with the blue wire conectors in the pics all seems good i will contact you via pm shortly Quote Link to comment Share on other sites More sharing options...
