MartinGT Posted August 21, 2008 Share Posted August 21, 2008 i think my clutch is on its way out, its started slipping under heavy load in higher gears. been offered the act organic clutch at a good price, does anyone have any experiences with them? any other clutches to consider? Quote Link to comment Share on other sites More sharing options...
bigphil Posted August 21, 2008 Share Posted August 21, 2008 i think my clutch is on its way out, its started slipping under heavy load in higher gears. been offered the act organic clutch at a good price, does anyone have any experiences with them? any other clutches to consider? ACT is a good unit but only really a benefit if you are changing the flywheel as well. The standard Exedy unit is more than capable of handling the power the Z can deliver and at £250 not too expensive. Other options would be the JWT. Quote Link to comment Share on other sites More sharing options...
MartinGT Posted August 21, 2008 Author Share Posted August 21, 2008 well if its buggered i'm as well getting one that can handle more power in the future really? the exedy just a standard spec? Quote Link to comment Share on other sites More sharing options...
bigphil Posted August 21, 2008 Share Posted August 21, 2008 well if its buggered i'm as well getting one that can handle more power in the future really? the exedy just a standard spec? Uprating is only really required if you are planning to go FI otherwise the standard clutch will handle this without issue. Quote Link to comment Share on other sites More sharing options...
MartinGT Posted August 21, 2008 Author Share Posted August 21, 2008 i plan to go FI in the future, hopefully! Quote Link to comment Share on other sites More sharing options...
