Guest prescience Posted January 4, 2006 Share Posted January 4, 2006 Zeitronix Wideband AFR Guide (www.zeitronix.com) http://www.zeitronix.com/installation/Z ... ctions.pdf The Zeitronix ZT-2 is a popular solution for providing monitoring of boost, wideband air-fuel ratio (AFR), exhaust gas temperature (EGT), lambda and RPM in real-time and offline (via an easily-connected laptop**) in Forced Induction applications. It is a neat alternative option for several additional gauges (e.g. in a Gauge Pod) and the sensors used are very high quality and accurate. ** The laptop will need a DB9 serial interface - so a laptop port replicator may be required Link to comment Share on other sites More sharing options...
