Z Boy Posted August 13, 2008 Share Posted August 13, 2008 Just taken the Z for an MOT and it failed on emissions, due to the high flow cats. Don't suppose anyone has a spare one lying around that I could borrow for a day? Quote Link to comment Share on other sites More sharing options...
bigphil Posted August 13, 2008 Share Posted August 13, 2008 Just taken the Z for an MOT and it failed on emissions, due to the high flow cats. Don't suppose anyone has a spare one lying around that I could borrow for a day? Should have passed easily with high flow's on, may have a dodgy lambda. Quote Link to comment Share on other sites More sharing options...
DJsickboy Posted August 13, 2008 Share Posted August 13, 2008 Just taken the Z for an MOT and it failed on emissions, due to the high flow cats. Don't suppose anyone has a spare one lying around that I could borrow for a day? Should have passed easily with high flow's on, may have a dodgy lambda. +1 It should have passed mate. Quote Link to comment Share on other sites More sharing options...
Z Boy Posted August 13, 2008 Author Share Posted August 13, 2008 Damn, that's not good then. The engine light is always on and I had it checked by Nissan and they said it's due to the aftermarket cats. So it could be a duff sensor then? Any idea how to check and how much a fix is? Thanks. Quote Link to comment Share on other sites More sharing options...
Andy Posted August 13, 2008 Share Posted August 13, 2008 If you get stuck, I can lend you some cats for the mot. Would agree on the above comments though, worth getting it checked out. Quote Link to comment Share on other sites More sharing options...
Z Boy Posted August 13, 2008 Author Share Posted August 13, 2008 So I need to get the lambda's checked out...anything else to get them to look at while I'm at it?! And cheers Andy, I'll let you know! Quote Link to comment Share on other sites More sharing options...
bigphil Posted August 13, 2008 Share Posted August 13, 2008 So I need to get the lambda's checked out...anything else to get them to look at while I'm at it?! And cheers Andy, I'll let you know! If the engine light is on it indicates you either have de cat pipes as opposed to high flows or that a lambda is malfunctioning. Looking at the pipe section does not always give an indication of having cats on the car as some of the decat pipes have a resonator section which looks very similar to the untrained eye as a cat. Quote Link to comment Share on other sites More sharing options...
Ebized Posted August 13, 2008 Share Posted August 13, 2008 So I need to get the lambda's checked out...anything else to get them to look at while I'm at it?! And cheers Andy, I'll let you know! If the engine light is on it indicates you either have de cat pipes as opposed to high flows or that a lambda is malfunctioning. Looking at the pipe section does not always give an indication of having cats on the car as some of the decat pipes have a resonator section which looks very similar to the untrained eye as a cat. Looks like you need to crawl under the car with a camera Quote Link to comment Share on other sites More sharing options...
bigphil Posted August 13, 2008 Share Posted August 13, 2008 So I need to get the lambda's checked out...anything else to get them to look at while I'm at it?! And cheers Andy, I'll let you know! If the engine light is on it indicates you either have de cat pipes as opposed to high flows or that a lambda is malfunctioning. Looking at the pipe section does not always give an indication of having cats on the car as some of the decat pipes have a resonator section which looks very similar to the untrained eye as a cat. Looks like you need to crawl under the car with a camera that would help us identify what is on the car. Quote Link to comment Share on other sites More sharing options...
bigphil Posted August 13, 2008 Share Posted August 13, 2008 to help with identification. in the pic below top high flow cat middle resonated decat bottom full straight decat Quote Link to comment Share on other sites More sharing options...
Z Boy Posted August 13, 2008 Author Share Posted August 13, 2008 Thanks for the pics guys. The guy I bought it off reckons it definitely has a high flow cat, but I'll check when I can to see which one it looks like. If it's a fauly Lambda is that gonna cost me mega bucks? Quote Link to comment Share on other sites More sharing options...
Digsy Posted August 13, 2008 Share Posted August 13, 2008 This was Danny's car. I'm surprised you didn't fit them, Phil. Quote Link to comment Share on other sites More sharing options...
Z Boy Posted August 13, 2008 Author Share Posted August 13, 2008 Yeah it was Limiters car if that helps, dunno if anyone knows what he had put on it!? Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted August 13, 2008 Share Posted August 13, 2008 Nemesis did some work on the car but I'm not sure exactly what. Quote Link to comment Share on other sites More sharing options...
Z Boy Posted August 13, 2008 Author Share Posted August 13, 2008 I know that engine wise the only modifications are the Nismo exhaust and the cats, besides that (and a plenum spacer) it's basically standard. Just had a P1 or P2 service (can't remember which lol), would they have changed the o2 sensors then? Quote Link to comment Share on other sites More sharing options...
bigphil Posted August 13, 2008 Share Posted August 13, 2008 This was Danny's car. I'm surprised you didn't fit them, Phil. no we didn't do any work on Dannys car. Lambdas would not be touched on a service. Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted August 13, 2008 Share Posted August 13, 2008 Only if they were faulty and probably not without notifying you first. Even if they didn't get your permission, they will be itemised on the invoice. Quote Link to comment Share on other sites More sharing options...
Z Boy Posted August 13, 2008 Author Share Posted August 13, 2008 I'll see if I can get them to check them out then, as I can't think what else could be causing the emissions to fail. Quote Link to comment Share on other sites More sharing options...
Sarnie Posted August 13, 2008 Share Posted August 13, 2008 Ask Danny who fitted the cats? Quote Link to comment Share on other sites More sharing options...
200sx Posted August 14, 2008 Share Posted August 14, 2008 Just a quick question from a newbe, but why would the engine warning light come on with a decat? Are there any sensors down stream of the cat? Quote Link to comment Share on other sites More sharing options...
200sx Posted August 14, 2008 Share Posted August 14, 2008 Just had a look at the service manual and it looks like there is a 2nd o2 sensor intergrated into the cats. I am guessing the high flow cats don't have a lambda sensor build in? Quote Link to comment Share on other sites More sharing options...
bigphil Posted August 14, 2008 Share Posted August 14, 2008 Just had a look at the service manual and it looks like there is a 2nd o2 sensor intergrated into the cats.I am guessing the high flow cats don't have a lambda sensor build in? lambdas are located one on either cat both on standard and high flow, the problem with the decats is the sensors sit too much in the gas flow. Quote Link to comment Share on other sites More sharing options...
Stew Posted August 14, 2008 Share Posted August 14, 2008 They plug in don't they? My light came on now and then when I put on plenum, pop charger and Exhaust. I did a reset and hasn't even come on again. Quote Link to comment Share on other sites More sharing options...
Ian Posted August 14, 2008 Share Posted August 14, 2008 My light comes on every 3k miles. I have decats that were rebuilt into hi flow cats though. Quote Link to comment Share on other sites More sharing options...
Andy Posted August 14, 2008 Share Posted August 14, 2008 The sensors screw into the cats then the cables loop round and hook into holders then clip into the connecters. Just as a point of reference, I have K8N Typhoon Kit, Plenum, Hi-Flo Cats and Nismo exhaust and have never had problems. Quote Link to comment Share on other sites More sharing options...
