Drexyl Posted August 7, 2008 Share Posted August 7, 2008 Parcel arrived today with my bits inside. The fastest delivery of all time, methinks! No sooner do I think "the weather's nice I'll crack on with this" and it starts slinging it down! Still, had enough time to fit the pop charger, so it's not all bad. will have a crack at the plenum spacer tomorrow. Thanks again for your help and advice, Phil, and I'm looking forward to dealing with you again. Carleton ps. my engine warning light has now come on since fitting the charger, will this go out once the ecu picks up the mod? Quote Link to comment Share on other sites More sharing options...
Ekona Posted August 7, 2008 Share Posted August 7, 2008 Nope, you've probably got an air leak post-MAF if it's only come on since fitting the Popcharger. Check the connections and run through the CEL reset procedure. Quote Link to comment Share on other sites More sharing options...
Drexyl Posted August 7, 2008 Author Share Posted August 7, 2008 Eh? Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted August 7, 2008 Share Posted August 7, 2008 drexyl, where have you been ? ... not prison again ? the light might require an ecu reset, check you have plugged the connector back into the maf maf = the black box on the tube that you have fitted the popcharger to this isn't common but not unknown with a popcharger install, usually a reset cures it Quote Link to comment Share on other sites More sharing options...
Ekona Posted August 7, 2008 Share Posted August 7, 2008 You haven't done the clips up properly and have air entering the engine which is unmetered (meaning you're probably running quite lean, which is a Bad Thing). Check all the connections are tight and reset the Check Engine Light (CEL) as described on one of the Stickys around here. Quote Link to comment Share on other sites More sharing options...
Drexyl Posted August 7, 2008 Author Share Posted August 7, 2008 drexyl, where have you been ? ... not prison again ? Hey Gix, I'm always about, well sorta, when I'm not away working. But it's good to be at home for a while. Here til the 20th, then it's all go again. gotta cram in as much modding as possible, but not if my warning lights are gonna keep coming on!!! Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted August 7, 2008 Share Posted August 7, 2008 its no biggee mate, try these... check the big jubilee clip is tight as ekona says check you plugged the connector in the maf do an ecu reset http://www.350z-uk.com/forum/viewtopic ... hlight=ecu Quote Link to comment Share on other sites More sharing options...
Drexyl Posted August 7, 2008 Author Share Posted August 7, 2008 its no biggee mate, try these... check the big jubilee clip is tight as ekona says check you plugged the connector in the maf do an ecu reset http://www.350z-uk.com/forum/viewtopic ... hlight=ecu Thanks bud, will have to try that in the morning now, as the rain looks set for the rest of this evening. I was sure the jubilee clip was tigh, and I definitly plugged in the connector, but I'll double check before doing the ecu thing. Quote Link to comment Share on other sites More sharing options...
Ekona Posted August 7, 2008 Share Posted August 7, 2008 If it's any consolation, I totally forgot to do the clip that holds the actual filter on when I did mine! It was only when I stopped and had a quick fumble to make sure everything was tight I realised that I'd got a bit too excited about getting it done and rushed it... Quote Link to comment Share on other sites More sharing options...
H5 Posted August 8, 2008 Share Posted August 8, 2008 Check the guides section and do the ECU reset procedure. Depending what you may or may not have nudged during installation, you may need to do the throttle position reset procedure too. Quote Link to comment Share on other sites More sharing options...
Drexyl Posted August 8, 2008 Author Share Posted August 8, 2008 Okay, just got in from fitting my plenum spacer (for which I bled and swore quite a lot!) and all is well. No air leaks, minor coolant leak quickly fixed, and I'm feeling a bit chuffed Not being what you call "mechanically minded", meaning I normally end up in a far worse situation than I would be if I'd left it alone, I'm pleased with the result I even managed to fit on the new set of PIAA wipers I got with barely scraped knuckles And after a few trys at it, I eventually managed to reset the ecu so it's not displaying the warning light. I am the preverbial happy bunny Thanks Phil Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted August 8, 2008 Share Posted August 8, 2008 well in mate now do the window reset and check the little rubber door switch inside the door shut is tight Quote Link to comment Share on other sites More sharing options...
Pimm Posted August 9, 2008 Share Posted August 9, 2008 Does the car run without any flashing warning lights now ?? and are you happy with the performance ?? Quote Link to comment Share on other sites More sharing options...
Drexyl Posted August 9, 2008 Author Share Posted August 9, 2008 Does the car run without any flashing warning lights now ?? and are you happy with the performance ?? No flashing lights, nor static ones either for that matter. As for performance, haven't yet had a chance to really test it, but it don't 'arf sound nice Quote Link to comment Share on other sites More sharing options...
martinmac Posted August 9, 2008 Share Posted August 9, 2008 Another £10 well spent Quote Link to comment Share on other sites More sharing options...
