jim Posted July 24, 2008 Share Posted July 24, 2008 I am trying to fit Spill's grounding kit to my car. There appears to be a problem in that my car (a JDM) already has a component attached to the rear right socket on the plenum, which is where I am instructed to attach three of the grounding cables. There's not enough room for them all. Anybody come across this and can help? Quote Link to comment Share on other sites More sharing options...
Beavis Posted July 24, 2008 Share Posted July 24, 2008 I am trying to fit Spill's grounding kit to my car. There appears to be a problem in that my car (a JDM) already has a component attached to the rear right socket on the plenum, which is where I am instructed to attach three of the grounding cables. There's not enough room for them all. Anybody come across this and can help? What is attached there? Any pics? Quote Link to comment Share on other sites More sharing options...
jim Posted July 24, 2008 Author Share Posted July 24, 2008 I am trying to fit Spill's grounding kit to my car. There appears to be a problem in that my car (a JDM) already has a component attached to the rear right socket on the plenum, which is where I am instructed to attach three of the grounding cables. There's not enough room for them all. Anybody come across this and can help? What is attached there? Any pics? I have a couple of pics but I can't remember how to get them into a post. Quote Link to comment Share on other sites More sharing options...
IanS16 Posted July 24, 2008 Share Posted July 24, 2008 I am trying to fit Spill's grounding kit to my car. There appears to be a problem in that my car (a JDM) already has a component attached to the rear right socket on the plenum, which is where I am instructed to attach three of the grounding cables. There's not enough room for them all. Anybody come across this and can help? Try PM'ing kingbiscuit.. he had the same problem but sorted it! Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted July 24, 2008 Share Posted July 24, 2008 open a photobucket account, upload the pics, copy the image tag, hit fast reply on here, press ctrl and v keys together, html link appears, finnish message, click submit, Done! Quote Link to comment Share on other sites More sharing options...
jim Posted July 24, 2008 Author Share Posted July 24, 2008 Thanks. Hope this helps. Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted July 24, 2008 Share Posted July 24, 2008 Remove it, its just somesort of bypass you dont need! I think some people have upgraded the CAI tube though.... You can attach the ground wire under it and then keep that tube on.... You may need a longer screw due to 3 wires attaching though... Mark Quote Link to comment Share on other sites More sharing options...
jim Posted July 24, 2008 Author Share Posted July 24, 2008 Remove it, its just somesort of bypass you dont need! I think some people have upgraded the CAI tube though.... You can attach the ground wire under it and then keep that tube on.... You may need a longer screw due to 3 wires attaching though... Mark Job done - I used a longer bolt as suggested. Cheers. Quote Link to comment Share on other sites More sharing options...
