H5 Posted July 22, 2008 Share Posted July 22, 2008 ......or is there some procedure that the handbook neglects to tell me that means I won't fry something important / expensive?? It's dead after 3 weeks of no use at all. Quote Link to comment Share on other sites More sharing options...
TT Convert Posted July 22, 2008 Share Posted July 22, 2008 No, jump that baby......................... or call the AA to do it for ya Quote Link to comment Share on other sites More sharing options...
Renegade Posted July 22, 2008 Share Posted July 22, 2008 I got to wondering how you would bump start it, seeing as you have to press the clutch in to start it.How do we go on there then Quote Link to comment Share on other sites More sharing options...
davej Posted July 22, 2008 Share Posted July 22, 2008 i've had to bump start mine twice now, as i've had the starter fail to engage, same theory as normal, biggest problem i had was i park facing uphill and you really dont want to try and do a 3 point turn in a z with no power steering and unservoed brakes!!! makes a man of you!!! Dave Quote Link to comment Share on other sites More sharing options...
H5 Posted July 22, 2008 Author Share Posted July 22, 2008 No, jump that baby......................... or call the AA to do it for ya Ta, will sort it out tomorrow I think, too dark now to start messing! Quote Link to comment Share on other sites More sharing options...
Toon Chris Posted July 23, 2008 Share Posted July 23, 2008 Erm... doesn't bump starting knacker the cats due to petrol washing over them? Or is that some old wives tale or even just for old carb cars When jumping, connect the earth to the chassis, not the battery, although again, I thought jump-starting a modern car could fry the ecu?? Quote Link to comment Share on other sites More sharing options...
Beavis Posted July 23, 2008 Share Posted July 23, 2008 I think you need a new battery Rob, either that or you have something draining it. But a good battery should be fine not been used for 3 weeks. Quote Link to comment Share on other sites More sharing options...
H5 Posted July 23, 2008 Author Share Posted July 23, 2008 I think you need a new battery Rob, either that or you have something draining it. But a good battery should be fine not been used for 3 weeks. That's what I was thinking. I am heading up to the Sound Gallery on Sat to have the system checked, and a few more tweaks....!! Quote Link to comment Share on other sites More sharing options...
Zummertor Posted July 23, 2008 Share Posted July 23, 2008 Simple things like leaving seat heaters on can be enough to cause an issue, agree that after 3 wks a good battery should still be a good battery. Is there a definitive answer on to bump start or not to bump start a Zed ? Must admit I'd probably not try it but still interesting to know. Quote Link to comment Share on other sites More sharing options...
Pingu2 Posted July 24, 2008 Share Posted July 24, 2008 no idea on bumping but have had to jump start mine several times now (after letting it sit for a few weeks!) - one thing is that I had to get thicker jumper cables than the ones I have had for 15 years.. Quote Link to comment Share on other sites More sharing options...
H5 Posted July 28, 2008 Author Share Posted July 28, 2008 It looks like I have a bluetooth module staying on, so that may be the cause of the drain. We didn't have a chance to do much on Saturday in the end. Quote Link to comment Share on other sites More sharing options...
Zummertor Posted July 28, 2008 Share Posted July 28, 2008 Could easily be something as apparently small as that. Bluetooth is still a power user for its range, the newer items like wibree that have been incorporated into Bluetooth standard should reduce that usage over time. Quote Link to comment Share on other sites More sharing options...
H5 Posted July 28, 2008 Author Share Posted July 28, 2008 It is the Alpine bluetooth kit, so if it is on there will be some current drain. I was thinking how long it was, and it was 3 1/2 weeks, which is probably enough to consume the battery's stored power. Quote Link to comment Share on other sites More sharing options...
