SwissZ Posted July 22, 2008 Share Posted July 22, 2008 Before I go and bother my garage again.... Was in a car park, went from a half right lock to a full left lock pulling into a space and the power steering appeared to pack in. Steering became very heavy and I ended up half a space away from where I was aiming for. There were no strange noises or anything Anyone else experienced this? I've got 19"s on but I woudn't expect them to be the cause. Cheers Mark Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted July 22, 2008 Share Posted July 22, 2008 is it ok now ? if not it sounds like the pumps knackered check your fuid level Quote Link to comment Share on other sites More sharing options...
Toon Chris Posted July 22, 2008 Share Posted July 22, 2008 Def check the fluid level. Presuming it is working again now you may have got an air-lock if it is a bit low, or you have a leak. Check the fluid is clean too. Quote Link to comment Share on other sites More sharing options...
SwissZ Posted July 22, 2008 Author Share Posted July 22, 2008 Ah, yes. I forgot to mention it's been fine since. Haven't checked the fluid level so I'll get on to that. How would I identify/get rid of an air lock? Cheers Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted July 22, 2008 Share Posted July 22, 2008 Ah, yes. I forgot to mention it's been fine since. Haven't checked the fluid level so I'll get on to that. How would I identify/get rid of an air lock? Cheers To bleed out any air, start the engine and turn the steering wheel fully from side to side slowly. This will force the air into the reservoir and out of the system. . Quote Link to comment Share on other sites More sharing options...
