mec Posted July 21, 2008 Share Posted July 21, 2008 Just been messing about with this proscan software... yeah really should be working but you know what it's like Didn't run her that hard, dropped the clutch at about 2,000rpm and changed just over 6k. (temp 16 degrees and about an 1/8th fuel in the tank) I was surprised at the time, was expecting to see 6 something. Didn't have enough distance to do the rest so i'd thought it best to mask them out. Quote Link to comment Share on other sites More sharing options...
mec Posted July 21, 2008 Author Share Posted July 21, 2008 Oh forgot to mention, ESP was off Quote Link to comment Share on other sites More sharing options...
Chris`I Posted July 21, 2008 Share Posted July 21, 2008 Is that using the OBD-II port? I have a similar feature on my OBD software though never tested it. How accurate is it? Cos if it just uses OBD-II I didnt think the refresh was quick enough to get accurate times? Did you have it only polling the car speed? If so I guess that could work quick enough. Must resist giving it a go myself Quote Link to comment Share on other sites More sharing options...
mec Posted July 21, 2008 Author Share Posted July 21, 2008 Yes it is using the OBDII port, I don't know how accurate it is... I'm guessing it is not going to be bang on the money but close I've haven't tried the dyno, I've added in the drag coeff, tire size and vehicle weight... the weight is just the manufactures guide though i'm sure the gt pack must add a bit... electric seat motors aren't going to be light. Should give a baseline though should I add any mods. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted July 22, 2008 Share Posted July 22, 2008 Cool - might give it a go in mine and see how they compare Quote Link to comment Share on other sites More sharing options...
