mec Posted July 18, 2008 Share Posted July 18, 2008 Just wondering what everyone's thoughts are on this, I've had the car a couple of weeks now and starting to get to get a feel for it. I've noticed that 1st to 2nd is a little notchy... 5th to 6th at speed can feel a bit notchy too... It's not crunching so i don't think the syncros are shot, just giving a little more resistance that i expected if you know what i mean. The odd thing is, if i have given the car some beans on a good drive the gearbox is smooth through all gears... Do you think a gearbox oil change will help? or is this all completely normal Cheers Gi Quote Link to comment Share on other sites More sharing options...
Stew Posted July 18, 2008 Share Posted July 18, 2008 how quick do you change? Try slowing down 1st to 2nd. Just leave an extra second when changing. Quote Link to comment Share on other sites More sharing options...
mec Posted July 19, 2008 Author Share Posted July 19, 2008 yeah if i go slow or double declutch it is smooth. Once everything is very hot then even a fast change from 1st to 2nd is smooth. Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted July 19, 2008 Share Posted July 19, 2008 What you're describing is a typical Zed gearbox. As has already been said, take your time on the changes when its cold and if its ok when hot then it should be fine. Quote Link to comment Share on other sites More sharing options...
dcash5 Posted July 20, 2008 Share Posted July 20, 2008 Depends what year zed u have the older ones has a crap syncro in the gear box which meant it was crunchy going 5th to 6th at speed. Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted July 20, 2008 Share Posted July 20, 2008 Depends what year zed u have the older ones has a crap syncro in the gear box which meant it was crunchy going 5th to 6th at speed. Yeah, but that issue is worse when it's hot - not the case here Why not change for a synthetic gear oil - Amsoil do a good one Quote Link to comment Share on other sites More sharing options...
sinbad Posted July 20, 2008 Share Posted July 20, 2008 i had nissan change my gearbox oil and it made my gearbox worse. i never had any problems with 1st -2nd until the oil was changed.. Quote Link to comment Share on other sites More sharing options...
mec Posted July 21, 2008 Author Share Posted July 21, 2008 Thanks guys, sounds like changing the oil could be hit or miss. I'll see if I can adjust my driving style first Quote Link to comment Share on other sites More sharing options...
mec Posted November 28, 2008 Author Share Posted November 28, 2008 After trying for a while I found i couldn't live with it, it's going in on Weds next week to have the transmission oil changed. Had to ask Nissan nicely to do the work as they orginally said they wouldn't stick the oil i bought in it, they'd only stick in the Nissan stuff... but after a little chat they knew it was a known problem and agreed that changing it with the nissan oil (75w-85) would do nothing. One of the engineers said they had good results with some Mobil EP 80w-90 oil... So i had a look around but in the end went for Mobil Modilube 1 SHC 75w-90 off of Opie oils... if it doesn't work i will probably go with redline's heavyshock, but as Opie doesn't have it listed for the car i thought i'd try the Mobil (I didn't think it wise to go against Opie's judgement and price )... I'll let you guys know how it goes. Quote Link to comment Share on other sites More sharing options...
Ekona Posted November 28, 2008 Share Posted November 28, 2008 I've used Redline MT-90 in the past and it's fantastic stuff, would definitely recommend it and it's what I'll use on the Zed when the time comes for me to change my gearbox oil. Quote Link to comment Share on other sites More sharing options...
P15UL T Posted November 28, 2008 Share Posted November 28, 2008 I always change my gearbox oil at every service and also use opie oils for all my lubricants. To be honest I think I'm quite lucky as I have never had any gearbox problems and when it's heated up it pretty solid Paul Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted November 28, 2008 Share Posted November 28, 2008 also use opie oils for all my lubricants. all ? Quote Link to comment Share on other sites More sharing options...
P15UL T Posted November 28, 2008 Share Posted November 28, 2008 also use opie oils for all my lubricants. all ? aye, can be a hassle cleaning the bed sheets Quote Link to comment Share on other sites More sharing options...
mec Posted December 3, 2008 Author Share Posted December 3, 2008 Got the car back and took it for a 10mile run, the box was warm but must say it feels better and quick changes don't crunch. It's not smooth as silk, but feels a lot less notchy. Quote Link to comment Share on other sites More sharing options...
mec Posted December 5, 2008 Author Share Posted December 5, 2008 ...hmm it's worse than before when cold. Anyone know how much it is to repair\exchange a box? Quote Link to comment Share on other sites More sharing options...
dcash5 Posted December 6, 2008 Share Posted December 6, 2008 try putting a gearbox additive in, molyslip or the like. Changing th box woul be about same price as replacing the clutch, just buying a box would be fairly expensive Quote Link to comment Share on other sites More sharing options...
mec Posted December 8, 2008 Author Share Posted December 8, 2008 Is it safe to do that, anyone tried Molyslip on a z? Quote Link to comment Share on other sites More sharing options...
