ab350z Posted July 5, 2008 Share Posted July 5, 2008 Folks, i wanted to ask what the best adhesive for fixing body parts to the car is? I've seen some of the sticky backed tapes but they tend to be quite thick so the fit isnt totally flush. Would rather a gel or paste of some sort and possibly something that isn't totally permanent. One of the items are headlight eyebrows that i'm not 100% sure of yet so i'd like the option of being able to remove them further down the line, without leaving sticky marks on the headlights. Any ideas? Quote Link to comment Share on other sites More sharing options...
Stew Posted July 5, 2008 Share Posted July 5, 2008 number plate fixer? Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted July 5, 2008 Share Posted July 5, 2008 Clear Silicon sealant is one option. Quote Link to comment Share on other sites More sharing options...
ab350z Posted July 5, 2008 Author Share Posted July 5, 2008 Presume that'll be available at B&Q? (other DIY stores are available) Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted July 5, 2008 Share Posted July 5, 2008 SILKAFLEX Quote Link to comment Share on other sites More sharing options...
DavidS14 Posted July 5, 2008 Share Posted July 5, 2008 The most popular for bodykit mounting seem to be Sikaflex and Tigerseal. From what I've read Tigerseal is stiffer and better if there's no flexing/movement in what you're fixing whereas Sikaflex is more flexible. http://shop.ebay.co.uk/?_from=R40&_trks ... w=sikaflex But they are really a permanent fix as once they cure it's very difficult to remove. I'm not sure that silicon sealant will give the adhesive properties you're after but it's difficult to find something else that will hold really well but is also easy to remove with no residue. Have you read http://www.350z-uk.com/forum/viewtopic.php?t=14856 as Marzman has just fitted eyebrows with silicon. Quote Link to comment Share on other sites More sharing options...
marzman Posted July 5, 2008 Share Posted July 5, 2008 The most popular for bodykit mounting seem to be Sikaflex and Tigerseal. From what I've read Tigerseal is stiffer and better if there's no flexing/movement in what you're fixing whereas Sikaflex is more flexible. http://shop.ebay.co.uk/?_from=R40&_trks ... w=sikaflex But they are really a permanent fix as once they cure it's very difficult to remove. I'm not sure that silicon sealant will give the adhesive properties you're after but it's difficult to find something else that will hold really well but is also easy to remove with no residue. Have you read http://www.350z-uk.com/forum/viewtopic.php?t=14856 as Marzman has just fitted eyebrows with silicon. Yeh i wouldnt use the tape... i taped a lip spoiler to my bmw a few years ago, and within a week it had fallen off! silkaflex is nasty stuff to work with - its like chewing gum. You wouldn't be able to use that on the headlights. ...silicone all the way! Quote Link to comment Share on other sites More sharing options...
kingbiscuit Posted July 8, 2008 Share Posted July 8, 2008 One of the items are headlight eyebrows that i'm not 100% sure of yet so i'd like the option of being able to remove them further down the line, without leaving sticky marks on the headlights. Any ideas? Do the headlight eyebrows look like these? Quote Link to comment Share on other sites More sharing options...
