stanski Posted June 26, 2008 Posted June 26, 2008 Today I decided ok I will try out warp speed on the Zed? Well after working my way through the gears and got to 6th planted my right foot and off we went - think I reached warp 3 but then it just did'nt want to go onto 4,5, or even further - am I doing somthing wrong? I checked the handbrake was'nt on and I switched the aircon off? I was told by the salemen that it will do at least warp factor 9 maybe 10 downhill with a good strong wind behind me? Is there a mod I can put on to reach that speed please? Thanks Oh the roof was up and my biggles scarf was safely tucked away in the boot in case your wondering about extra drag? Quote
mbs Posted June 26, 2008 Posted June 26, 2008 You're a nut case, beam me up Stanski and I'll try to fix it. Quote
martinmac Posted June 26, 2008 Posted June 26, 2008 Try putting some of what you are drinking in the zed Stan Quote
Lexx Posted June 26, 2008 Posted June 26, 2008 After reading that, I thought I was the one who'd been drinking! or smoking! Quote
stanski Posted June 26, 2008 Author Posted June 26, 2008 So you dont have a warp drive button on the dash like me ?? You see your just missing out! Quote
nixy Posted June 27, 2008 Posted June 27, 2008 you're bonkers, try an early night and see if that helps! Quote
Trev-the-Rev Posted June 27, 2008 Posted June 27, 2008 Check for bricks under the throttle pedal and large creatures hibenating under the bonnet and blocking the air intake Quote
nixy Posted June 27, 2008 Posted June 27, 2008 failing the above ask Scottie to check the dilithiam crystals? Quote
sl114 Posted June 27, 2008 Posted June 27, 2008 Is there a mod I can put on to reach that speed please? I hear Beavis is up for anything these days. Quote
Trev-the-Rev Posted June 27, 2008 Posted June 27, 2008 failing the above ask Scottie to check the dilithiam crystals? Never had you down as a Trekie, Nixy Quote
Zummertor Posted June 27, 2008 Posted June 27, 2008 Read this thread a couple of times and it is very troubling all round, you guys are nuts, but thank you as I feel totally normal now Quote
nixy Posted June 28, 2008 Posted June 28, 2008 failing the above ask Scottie to check the dilithiam crystals? Never had you down as a Trekie, Nixy erm, I'm not really honest, it's just my wide range of general knowledge. Quote
Trev-the-Rev Posted June 29, 2008 Posted June 29, 2008 failing the above ask Scottie to check the dilithiam crystals? Never had you down as a Trekie, Nixy erm, I'm not really honest, it's just my wide range of general knowledge. Of course it is Quote
DavidS14 Posted June 30, 2008 Posted June 30, 2008 Read this thread a couple of times and it is very troubling all round, you guys are nuts, but thank you as I feel totally normal now Shouldn't that be "tribbling".............I'll get my coat.... Quote
Zummertor Posted June 30, 2008 Posted June 30, 2008 Read this thread a couple of times and it is very troubling all round, you guys are nuts, but thank you as I feel totally normal now Shouldn't that be "tribbling".............I'll get my coat.... did you mean to say that ? - crikey of course if derived from tribe then very sharp but if the slang then ... well no it wasn't what I meant Quote
nixy Posted June 30, 2008 Posted June 30, 2008 Yes, the Tribbles - remember them well - look what Stan's started and he's not even here to take the blame! Quote
