gmaguire Posted June 25, 2008 Share Posted June 25, 2008 Hi, I just finished wiring the PAC ROEM-NIS2 loom with a new stereo with ISO connector. All the wires seem to match up ok as per both colour codes of wires and both stereo and PAC specs. I have a 03 Jap import ST/GT spec with BOSE system. But when I turn on ignition I do not get any life from unit, has anyone else experience of installing one of these ? Is there an extra magic wire that has to be connected, grounding issues, loops etc ? I have seen some other posts re the Mirca connector for non BOSE system and my OEM plugs look the same ... do I actually need the PAC unit as well ? Any info or ideas greatfully accepted. Thanks, Ger. Quote Link to comment Share on other sites More sharing options...
willo Posted June 25, 2008 Share Posted June 25, 2008 You have grounded it haven't you? black wire to the chasey? Quote Link to comment Share on other sites More sharing options...
gmaguire Posted June 25, 2008 Author Share Posted June 25, 2008 You have grounded it haven't you? black wire to the chasey? The black ground is wired in as part of the harness and the adaptors not directly to the chassis, does it need a second or direct ground also ? Ger. Quote Link to comment Share on other sites More sharing options...
willo Posted June 25, 2008 Share Posted June 25, 2008 Yep, it needs to be directly attched to the chassis. On mine I connected the 2 black wires from the Pac unit to the HU together but also joined another wire which I used as ground. Think there is a thread, but the Bose doesn't have a proper ground via the wiring loom hence why its grounded by the chassis. Quote Link to comment Share on other sites More sharing options...
gmaguire Posted June 25, 2008 Author Share Posted June 25, 2008 Yep, it needs to be directly attched to the chassis. On mine I connected the 2 black wires from the Pac unit to the HU together but also joined another wire which I used as ground. Think there is a thread, but the Bose doesn't have a proper ground via the wiring loom hence why its grounded by the chassis. Kewl, ta for that, I'll do that this evening and let you know how I get on. Ger. Quote Link to comment Share on other sites More sharing options...
gmaguire Posted June 25, 2008 Author Share Posted June 25, 2008 Yep, it needs to be directly attched to the chassis. On mine I connected the 2 black wires from the Pac unit to the HU together but also joined another wire which I used as ground. Think there is a thread, but the Bose doesn't have a proper ground via the wiring loom hence why its grounded by the chassis. Kewl, ta for that, I'll do that this evening and let you know how I get on. Ger. Hiya, OK I have now have power but no sound, do I have to change the speaker settings on the PAC unit ? Don't want to mess with it too much unless I know what I'm doing, instruction sheet pretty says plug it in and it should work ? Quote Link to comment Share on other sites More sharing options...
willo Posted June 25, 2008 Share Posted June 25, 2008 I think there are 2 blue wires from the pac unit, 1 is the power ariel and the other is the power amp. You need to connect the power amp cable to the blue coming from your HU. No power to the amp, no sound. I think you may need to hook up the blue ariel wire as well, so 2 blue wires from PAC to 1 blue wire from HU. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted June 25, 2008 Share Posted June 25, 2008 I think there are 2 blue wires from the pac unit, 1 is the power ariel and the other is the power amp. You need to connect the power amp cable to the blue coming from your HU. No power to the amp, no sound. I think you may need to hook up the blue ariel wire as well, so 2 blue wires from PAC to 1 blue wire from HU. Yup and Yup Quote Link to comment Share on other sites More sharing options...
gmaguire Posted June 25, 2008 Author Share Posted June 25, 2008 I think there are 2 blue wires from the pac unit, 1 is the power ariel and the other is the power amp. You need to connect the power amp cable to the blue coming from your HU. No power to the amp, no sound. I think you may need to hook up the blue ariel wire as well, so 2 blue wires from PAC to 1 blue wire from HU. Willo, your a star, thanks for all the help, i had the blue to blue ok but not the blue/white, Kenwood DNX 5220 unit not fully working installed and working with sat/nav, bluetooth and ipod Ger. Quote Link to comment Share on other sites More sharing options...
