APS 350Z extreme fuel system, suits twin turbo, large single
Removed
from 350z-tech
here's the first available pic of the APS extreme fuel system for high powered twin turbo VQ engines. The extreme fuel system has been tested by APS over the last 12 months and will be available in the US this coming June.
The APS extreme fuel system is designed for high powered twin turbo engines though could easliy be utilised for SC engines. With twin high volume fuel pumps (complete stainless steel fabricated drop in fuel pump assembly), twin teflon lined stainless steel fuel supply lines, billett fuel rails/ 58 PSI fuel regs and full fuel return system, massive 880 cc injectors and all required fitting hardware, this is the real deal for guys wanting a massive all encompassing fuel supply system for reliable fuel supply, critical for engine durability at high power levels.
