LewisL Posted June 24, 2008 Posted June 24, 2008 Hello, Silly question to you I'm surebut i a buggered if i can change the rear wiper blade? the arm wont move enough to get the old 1 out!is there a nack to it!? or is my arm just stiff & needs a bit of force!? just dont wanna break it! cheers Quote
rmmackfc Posted June 24, 2008 Posted June 24, 2008 Arm will only lift about 1-2". IIRC there is a clip keeping the blade in position. Press and slide... Someone will be able to confirm this though Quote
Chris`I Posted June 24, 2008 Posted June 24, 2008 Arm will only lift about 1-2".IIRC there is a clip keeping the blade in position. Press and slide... Someone will be able to confirm this though Sounds about right. Not done the rear, but on the front there is a little tab to pust then the wiper slides out. Just like most other cars. Only you have less room Quote
LewisL Posted June 24, 2008 Author Posted June 24, 2008 cheers boys! sorted it! How do i change the side lights? have i got to take the wheel off & go through the arch? Thanks, Quote
Chris`I Posted June 24, 2008 Posted June 24, 2008 cheers boys! sorted it! How do i change the side lights? have i got to take the wheel off & go through the arch? Thanks, Throught the arch is the easiest method. Turn the wheel so that the wheel is in the arch at the front (ie if doing the drivers side, turn the wheel to the left) to give you plenty of room. Then undo the two bottom bolts on the arch liner and the 1 or 2 screws in the lining on the side. Then pull it out and you should get just enough access for the side lights. I think some jack the car up too to get more room Quote
