Appo Posted June 23, 2008 Share Posted June 23, 2008 Hi My driver's window is stuck in the 'down by 10mm' position, and won't budge when door shuts or using control switch. It did this a few days ago and then worked again. Is it likely to be a loose connection, or busted motor? PS When I manually push the door closure switch on the door frame, there is a click from the motor area but no movement. At least it isn't stuck all the way down Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted June 23, 2008 Share Posted June 23, 2008 Check the forums, well documented, either the case your motor has died or just needs a clean. Instructions to do somewhere. What year car? Could be a wtee job? Quote Link to comment Share on other sites More sharing options...
Appo Posted June 23, 2008 Author Share Posted June 23, 2008 I'll have a look, didn't spot any posts first time - thanx 53 reg UK model wtee=what? Quote Link to comment Share on other sites More sharing options...
martinmac Posted June 23, 2008 Share Posted June 23, 2008 Not exactly the same as yours but some usfeul info bud. http://www.350z-uk.com/forum/viewtopic ... ght=window Quote Link to comment Share on other sites More sharing options...
nixy Posted June 24, 2008 Share Posted June 24, 2008 this is quite common but you'll never get a second hand motor off ebay if you need one cos Tim collects them! Quote Link to comment Share on other sites More sharing options...
D12BHP Posted June 24, 2008 Share Posted June 24, 2008 I had a similar problem turned out to the window regulator and not the motor...if your hear the clicking should be ok?? Quote Link to comment Share on other sites More sharing options...
