Vertakill Posted June 22, 2008 Share Posted June 22, 2008 This has happened me more and more often lately, and usually rectified within a couple seconds of it happening. However, after going over a biggish pothole, the display/speedo stopped working for at least 30 mins. It eventually came back, only for it to stop working again a little while later. This is every dial on your display directly in front of you - fuel, speedo, rpm etc. Also, the smaller LED displays on your left - batt voltage, oil, multi-function dial. Any ideas what I can do? Could it just be a cable that powers the entire display, and where should I be looking? It's quite difficult to physically get your head around that area as theres not much space for your head between the steering wheel/windscreen. Any help is much appreciated, as the main one that's worrying me is the lack of being able to see the fuel gauge and the MPG is naturally fairly woeful. Quote Link to comment Share on other sites More sharing options...
Ian Posted June 22, 2008 Share Posted June 22, 2008 It is powered by a single cable. I think its behind the 3 gauges but not 100% sure. Quote Link to comment Share on other sites More sharing options...
Vertakill Posted June 22, 2008 Author Share Posted June 22, 2008 I had a look behind the speedo and saw 2 cables, left and right. Both seemed fine. I'll try take the whole speedo off when I have a chance and have a better look. Cheers Ian. Quote Link to comment Share on other sites More sharing options...
Sarnie Posted June 29, 2008 Share Posted June 29, 2008 Did you end up with that zed in Stafford? Quote Link to comment Share on other sites More sharing options...
Madmarky Posted July 1, 2008 Share Posted July 1, 2008 When i installed the my stereo i disconnected the battery. Upon reconnecting it none of my dials stopped working just like yours. I thought i hadnt connected something up correctly but left it for a bit and they started working again. I know this does not really help you but i think it takes time to reset itself somehow so maybe you have a loose wire. Hope ya find out the problem as i can imagine how annouying it is. Quote Link to comment Share on other sites More sharing options...
