Rob_Quads Posted June 21, 2008 Share Posted June 21, 2008 This is for the two subwoofer enclosures & the panel that sits between the two boxes. The trim panel could also be used for mounting an amp if you wanted to. I am also including the panel which goes under the strut bar which originally held my amp but would need adapting & retrimming for another amp The subs used are Hertz Audio 8" subs. Even though these are small subs they can produce a surprising amount of rumble. The are designed to power by around 300W rms The sub boxes are made from a combination of wood and fibreglass. I made the boxes myself to fit perfectly between the rear speakers and the strut brace. The boxes are very solid and finished in a carbon effect vinyl. The Subs used in this install are two Hertz audio subs. This is a company which produces good quality audio components and is owed by the same company as the likes of Audison. Although its a fairly exposed system due to the way it sits and is finished you don't really notice it from outside unless you really look into the cabin. Specs of the subs - Hertz Audio HX 200 (8") : PDF of Specs [*]300 Watt RMS (600 Watt Max) [*]4 Ohm [*]High thermal dissipation and magnetic permeability plates. [*]Double magnet motor. [*]Superior “T†Quote Link to comment Share on other sites More sharing options...
live2themaxuk Posted June 22, 2008 Share Posted June 22, 2008 Bump for a good sale Quote Link to comment Share on other sites More sharing options...
IanS16 Posted June 24, 2008 Share Posted June 24, 2008 Did you have to rip out the Bose to install these? Quote Link to comment Share on other sites More sharing options...
Rob_Quads Posted June 24, 2008 Author Share Posted June 24, 2008 Nope. This can all be installed without 'ripping' out the Bose system. You would need an appropriate amp to power them which would need a feed which can either be taken from the factor unit or an after market depending on how you want to do it. If you are worried about making sure you can return it to standard this fits that model as you would just need to plug all the standard connections in again and your back to the duff BOSE again Quote Link to comment Share on other sites More sharing options...
c12nny Posted July 5, 2008 Share Posted July 5, 2008 still for sale m8?? Quote Link to comment Share on other sites More sharing options...
Rob_Quads Posted July 5, 2008 Author Share Posted July 5, 2008 Provisionally sold - Just checking how much its going to ship the install. Quote Link to comment Share on other sites More sharing options...
