Dragun Posted June 10, 2008 Share Posted June 10, 2008 Hi guys, I need to remove the speedo clocks in order to remove a bulb so that the airbag light wont stay on ( as air bag was removed and this will not reset). Just wondering if anyone could direct me on how to do this. Thanks Quote Link to comment Share on other sites More sharing options...
Digsy Posted June 10, 2008 Share Posted June 10, 2008 Hi guys, I need to remove the speedo clocks in order to remove a bulb so that the airbag light wont stay on ( as air bag was removed and this will not reset). Just wondering if anyone could direct me on how to do this. Thanks PM lomoto - he's done it. Quote Link to comment Share on other sites More sharing options...
lomoto Posted June 10, 2008 Share Posted June 10, 2008 Undo 4 screws holding cowl around steering column, prise apart cowl ( a bit stiff thiese !! ), undo 4 10mm headed bolts that hold speedo assy on to steering column, pull out electrical block connector at the back of speedo and thats it ..10 min job Quote Link to comment Share on other sites More sharing options...
Digsy Posted June 10, 2008 Share Posted June 10, 2008 Undo 4 screws holding cowl around steering column, prise apart cowl ( a bit stiff thiese !! ), undo 4 10mm headed bolts that hold speedo assy on to steering column, pull out electrical block connector at the back of speedo and thats it ..10 min job We need a little write up with pics in the Guides section. Anyone want to oblige? Quote Link to comment Share on other sites More sharing options...
Zedrush Posted June 10, 2008 Share Posted June 10, 2008 Undo 4 screws holding cowl around steering column, prise apart cowl ( a bit stiff thiese !! ), undo 4 10mm headed bolts that hold speedo assy on to steering column, pull out electrical block connector at the back of speedo and thats it ..10 min job We need a little write up with pics in the Guides section. Anyone want to oblige? Ill give a go considering my vast knowledge in car mechanics... one of these ... or one of these should do the trick.. if any one needs help fitting a turbo kit dont be afraid to drop me a pm lol Quote Link to comment Share on other sites More sharing options...
Dragun Posted June 10, 2008 Author Share Posted June 10, 2008 Haha....ill...pass Ok im a try this tomorrow.... take pics as i do it so hopefully can be sticky in technical section. Thanks Quote Link to comment Share on other sites More sharing options...
Digsy Posted June 10, 2008 Share Posted June 10, 2008 Haha....ill...pass Ok im a try this tomorrow.... take pics as i do it so hopefully can be sticky in technical section. Thanks Good man! Quote Link to comment Share on other sites More sharing options...
jim Posted June 10, 2008 Share Posted June 10, 2008 Undo 4 screws holding cowl around steering column, prise apart cowl ( a bit stiff thiese !! ), undo 4 10mm headed bolts that hold speedo assy on to steering column, pull out electrical block connector at the back of speedo and thats it ..10 min job We need a little write up with pics in the Guides section. Anyone want to oblige? Ill give a go considering my vast knowledge in car mechanics... one of these (otherwise known as an Irish screwdriver)... lol Quote Link to comment Share on other sites More sharing options...
