kashz Posted June 10, 2008 Share Posted June 10, 2008 hi i just had my pads replaced and everytime im in reverse and braking the car tends to make a very loud squealing noise do my pads needs grinding ? Quote Link to comment Share on other sites More sharing options...
H5 Posted June 10, 2008 Share Posted June 10, 2008 Have you done the bedding in process that is posted in the guides section? Quote Link to comment Share on other sites More sharing options...
kashz Posted June 10, 2008 Author Share Posted June 10, 2008 i havnt yet but im gna after work hopefully it will be the solution to the problem .... is this normal tho does every 350z owner go through this squealin problem .. Quote Link to comment Share on other sites More sharing options...
marzman Posted June 10, 2008 Share Posted June 10, 2008 i havnt yet but im gna after work hopefully it will be the solution to the problem .... is this normal tho does every 350z owner go through this squealin problem .. Nope - i had my none-brembo rears replaced and there was no grinding at all. Who was it on here recently that put one of their pads in the wrong way round?? I'd find out which side it is, and pop you wheel off to see if you can see anything wrong. Quote Link to comment Share on other sites More sharing options...
kashz Posted June 10, 2008 Author Share Posted June 10, 2008 the pads are right its just really loud squealing i had to explain to my gf iv got new pads on do you know how hard that is lo l... iv got the brembo brakes does that make a difference Quote Link to comment Share on other sites More sharing options...
H5 Posted June 10, 2008 Share Posted June 10, 2008 Do the bedding in procedure, then see if it still makes the noise. Quote Link to comment Share on other sites More sharing options...
kashz Posted June 10, 2008 Author Share Posted June 10, 2008 i tried the procedure on the way home and it still makes the squealing sound but only when im in reverse and its from the rear .... Quote Link to comment Share on other sites More sharing options...
lomoto Posted June 10, 2008 Share Posted June 10, 2008 i tried the procedure on the way home and it still makes the squealing sound but only when im in reverse and its from the rear .... have you "copperslipped" the rear of the pads??, essential to stop brake squeal Quote Link to comment Share on other sites More sharing options...
kashz Posted June 11, 2008 Author Share Posted June 11, 2008 yep i did and still got the problem so going to put new pads and disk on rear so any tips Quote Link to comment Share on other sites More sharing options...
Sarnie Posted June 11, 2008 Share Posted June 11, 2008 yep i did and still got the problem so going to put new pads and disk on rear so any tips Bed them in properly or you'll 'glaze' them. I had my DS2500's fitted correctly, greased and follwed the bedding in procedure but they still squeeeeeled like buggery Quote Link to comment Share on other sites More sharing options...
