Used 350z ACT flywheel for sale
get12
Must have been expensive to swop to the ACT then to change again to the NISMO set up. How did the ACT and NISMO flywheels compare?
You are making assumptions without knowing the full story. The ACT flywheel was installed as part of a clutch disk up-grade - from OEM disk to Nismo disk, and as it happens, the Nismo disk did not react well with the OEM casing (which was not replaced). Which is why a complete Nismo clutch set (including casing) was installed, and as part of the package/deal the Nismo flywheel was included.
Not much difference between flywheels - once you get down to this sort of weight from OEM you are not going to feel much more of a difference. The 'chattering' is no more or less between the two.
So, as you can see - no hidden agenda.
