Newbie Z owner, Is this noise the norm?
TT Convert
Hello there, I have just purchased my first Z, I have had a noise from under the car, when its stood idle and not moving there is clunk 2or3 times then it rests for a few seconds then it happens again, it seems to be in time with a pop from the exhaust. any ideas anybody :wacko:
Also When the clutch isnt engaged thers no noise from it but when its dipped theres a very slight rubbing from the clutch, is this normal in the Z
so its nothing to worry about as Im a bit of a paniker, it feal quite a hefty movemt throught the pedals, if you know what I mean, when the noise happens I can feel it :blush::blush::blush:
try switching the air con off, if it doesnt make the noise then you have it sorted :thumbs:
also when i cahnge gear, if your stood outside that also is quite lound, unlike my girly TT, is this also the norm?
sorry I cant help on that , mine is soo bloody noisy with the Nismo exhaust , hi-flo cats , induction kit etc. etc. That I have fitted :lol:
one last question, are the Z know for having a high'ish clutch?? oh and thanks for the help ;-)
Dont know about a high clutch , they are known to be a bit heavier than most cars, if you have just bought it , it may be best to let the dealer have a look, or someone who has a Zed ??
he clutch rub thing is ok, as I have read on here its quite the norm, my main concern is the 2or3 clunks from under the car that seem to go in time with the engine and exhaust, the tick over dies slightly, I get the 2or3 clunks then a slight pop from the pipes
I have had my 350z for 2 weeks now... only 18k on the clock, they seem to be pretty clunky cars and you can sometimes hear the gear engagement and clutch bearing as you mentioned...
I have found some relief in reading your comments as it sounds like you are describing my car! lol
ohhh right, mine does have a duel then, and did you mean thinkinh not thining?? LoL. Got it booked in at a garage on tuesday who specialises in performance cars. He seems to know what he's talking about. Gunna get the P3 done for peice of mind and hes going to have a good look at it, I'll let yall know!
