M13KYF Posted May 20, 2008 Share Posted May 20, 2008 I'm after a alloy wheel cleaning pad. Like the wheel brushes you can get but with a microfibre sponge on the end instead of a brush and thin enough to get past the disc brakes. Anybody know of anything. Quote Link to comment Share on other sites More sharing options...
H5 Posted May 20, 2008 Share Posted May 20, 2008 Clean and shiny do a wheel Wash Shmitt but it doesn't have a handle, goes over your hand. Only other option is a homewares place that does the washing up brushes with the sponges on the end. Quote Link to comment Share on other sites More sharing options...
H5 Posted May 20, 2008 Share Posted May 20, 2008 This is kind of it, but isn't really sponge as such http://www.halfords.com/webapp/wcs/stor ... yrn_123049 Quote Link to comment Share on other sites More sharing options...
M13KYF Posted May 20, 2008 Author Share Posted May 20, 2008 yeah thats the kind a thing I'm after but I've seen those and they are not that soft Quote Link to comment Share on other sites More sharing options...
H5 Posted May 20, 2008 Share Posted May 20, 2008 Yeah, I know what you mean. Anyway, scrap that, I knew I'd seen one somewhere - it's here. IIRC it has a grey / black pad on the end that does the job. http://www.halfords.com/webapp/wcs/stor ... rn_123049# Quote Link to comment Share on other sites More sharing options...
M13KYF Posted May 20, 2008 Author Share Posted May 20, 2008 i'll check my local halfrauds, they've got them in stock. See if it's up to the job :thanks: Quote Link to comment Share on other sites More sharing options...
Stew Posted May 20, 2008 Share Posted May 20, 2008 I have ordered a variety of wheel brushes including a wheel back brush from polished bliss. They use them on the cars they detail so it's certainly up to the task and won't damage anything. If you want I can order some for you (-10%) or I'll let you know how I get on with them. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted May 21, 2008 Author Share Posted May 21, 2008 be interested tp know if it can get between the disc calliper and inner wheel rim. Quote Link to comment Share on other sites More sharing options...
H5 Posted May 21, 2008 Share Posted May 21, 2008 be interested tp know if it can get between the disc calliper and inner wheel rim. I tend to go for the 'get a cloth and pull it round while leaving all skin on the back of your hand on the brake disc' approach! Quote Link to comment Share on other sites More sharing options...
sl114 Posted May 21, 2008 Share Posted May 21, 2008 be interested tp know if it can get between the disc calliper and inner wheel rim. I tend to go for the 'get a cloth and pull it round while leaving all skin on the back of your hand on the brake disc' approach! Thats pretty much what i did and it worked, however the other route is to work around it, then wheel the car forward or backwards a small amount and clean the now unhidden area. My little feminine hands however enabled me to get behind the calipers on both the front and rear calipers Quote Link to comment Share on other sites More sharing options...
M13KYF Posted May 21, 2008 Author Share Posted May 21, 2008 be interested tp know if it can get between the disc calliper and inner wheel rim. I tend to go for the 'get a cloth and pull it round while leaving all skin on the back of your hand on the brake disc' approach! same problem for me and especially irritating on the rear disc with its knife edge protecting plate around the disc Quote Link to comment Share on other sites More sharing options...
H5 Posted May 21, 2008 Share Posted May 21, 2008 be interested tp know if it can get between the disc calliper and inner wheel rim. I tend to go for the 'get a cloth and pull it round while leaving all skin on the back of your hand on the brake disc' approach! same problem for me and especially irritating on the rear disc with its knife edge protecting plate around the disc That is someone's idea of a joke, most knifes aren't supplied that sharp. What about the Meguiars cone wheel brush, that collapses right down? Almost like a pipe cleaner. Works well for me. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted May 21, 2008 Author Share Posted May 21, 2008 never a fan of something that has twisted thick wire as a core of a brush Quote Link to comment Share on other sites More sharing options...
Stew Posted May 21, 2008 Share Posted May 21, 2008 Well I'll let you know when I try them out. I just used to pass the wash mitt that I used on my wheels round keeping my hands out the way! I did however still always end up with shredded hand syndrome! Quote Link to comment Share on other sites More sharing options...
sl114 Posted May 22, 2008 Share Posted May 22, 2008 I did try using the thin washing up pads at one point which tended to work quite well, however they just ended up being shredded themselves on the balancing weights and razor surrounding the rear brake discs! Quote Link to comment Share on other sites More sharing options...
clarkie34 Posted May 22, 2008 Share Posted May 22, 2008 Try the EZ Detail Wheel Brush.I have the Megs one but found this much better and longer will reach the inside of the rim no probs. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted May 23, 2008 Author Share Posted May 23, 2008 I was looking at that one after reading muddy details article in total nissan Is the wire very well protected on the brush part Quote Link to comment Share on other sites More sharing options...
clarkie34 Posted May 23, 2008 Share Posted May 23, 2008 Yes mate and the tip is rubber.Cleans the rim between the calliper aswell.They sell them at http://www.motorgeek.co.uk/exterior-whe ... 21_27.html Quote Link to comment Share on other sites More sharing options...
M13KYF Posted May 23, 2008 Author Share Posted May 23, 2008 yeah also seen it there. About the only place in the UK to get it Quote Link to comment Share on other sites More sharing options...
