SAFC99 Posted May 16, 2008 Share Posted May 16, 2008 Has anyone had a squeeky clutch pedal and what did you do to fix it? I cant tell if its from inside the cabin or in the engine bay. Quote Link to comment Share on other sites More sharing options...
Zummertor Posted May 16, 2008 Share Posted May 16, 2008 Not had this on the Zed but on a couple of Toyota's it has just been a lubrication issue. Quote Link to comment Share on other sites More sharing options...
TADDY Posted May 28, 2009 Share Posted May 28, 2009 my clutch pedal has just started too, took it back to nissan as they only fitted it last year and they have said it could be they arms around the clutch that have worn on one side or a lube issue. They also said that if its the arms it will be coverd by warranty but if its lube then it will cost me £350 for there time spent taking it apart!!!! gits! so im in a rite predicament Quote Link to comment Share on other sites More sharing options...
M13KYF Posted May 28, 2009 Share Posted May 28, 2009 moved Quote Link to comment Share on other sites More sharing options...
TADDY Posted May 28, 2009 Share Posted May 28, 2009 cheers Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 28, 2009 Share Posted May 28, 2009 my clutch pedal has just started too, took it back to nissan as they only fitted it last year and they have said it could be they arms around the clutch that have worn on one side or a lube issue. They also said that if its the arms it will be coverd by warranty but if its lube then it will cost me £350 for there time spent taking it apart!!!! gits! so im in a rite predicament If you pull back the rubber boot on the clutch fork on the side of the gearbox then you can get in to lub quite easily with a WD40 aerosol or similar. Also try lubricating the fulcrum and spring at the top of the clutch pedal. Quote Link to comment Share on other sites More sharing options...
FUG Posted August 29, 2012 Share Posted August 29, 2012 Also try lubricating the fulcrum and spring at the top of the clutch pedal. Is this a WD40 jobby too? Quote Link to comment Share on other sites More sharing options...
Watshot Posted August 29, 2012 Share Posted August 29, 2012 Yep, common problem on any make where dry parts move against each other. May need repeating every now and then. Quote Link to comment Share on other sites More sharing options...
FUG Posted August 30, 2012 Share Posted August 30, 2012 sorted Quote Link to comment Share on other sites More sharing options...
Hennerz Posted August 30, 2012 Share Posted August 30, 2012 sorted i got this problem, what did you do to fix it? Quote Link to comment Share on other sites More sharing options...
Vik54 Posted August 30, 2012 Share Posted August 30, 2012 sorted i got this problem, what did you do to fix it? This ... it does work my clutch pedal has just started too, took it back to nissan as they only fitted it last year and they have said it could be they arms around the clutch that have worn on one side or a lube issue. They also said that if its the arms it will be coverd by warranty but if its lube then it will cost me £350 for there time spent taking it apart!!!! gits! so im in a rite predicament If you pull back the rubber boot on the clutch fork on the side of the gearbox then you can get in to lub quite easily with a WD40 aerosol or similar. Also try lubricating the fulcrum and spring at the top of the clutch pedal. Quote Link to comment Share on other sites More sharing options...
