qmant123 Posted Monday at 19:49 Share Posted Monday at 19:49 Over the past 2 weeks, my 06' 350z has been acting up engine wise. There are no definite check engine lights, but when I prompted the computer with a scanner, it gave me the P1078 engine code. Some of the problems I've been having include: a shaky/unbalanced warm startup (low rpms, ratlting, and sounding like it might lean out and die), a sort of chittering from 2.5-3.5k rpm when accelerating in gear (again only when warm), very sub-par fuel economy, and more engine noise than i'm used to when parked and idling. I recently changed the oil which originally fixed the same chitter that I had around 4 months ago, and its sitting at 130k kms. I have heard that spark plugs/timing chain issues might be the source of the chittering/extra noise (which are still oem). For mods, I only swapped a different muffler in maybe 10 months ago, which hasn't been an issue until now. I kept all of the oxygen sensors and catalytic converters, as I didn't want to cause a big change in exhaust backflow, but maybe now it's the issue IDK. Any possible solutions or next steps of action would be really helpful thanks! Quote Link to comment Share on other sites More sharing options...
Keith D Posted Monday at 21:09 Share Posted Monday at 21:09 cam position sensor? Quote Link to comment Share on other sites More sharing options...
qmant123 Posted Monday at 21:48 Author Share Posted Monday at 21:48 yes, for bank 1 if im correct Quote Link to comment Share on other sites More sharing options...
Keith D Posted yesterday at 06:33 Share Posted yesterday at 06:33 Sorry I meant have you checked it? With those you can often do a voltage and continuity check with a multimeter. Google will be your friend. Quote Link to comment Share on other sites More sharing options...
