Gyrodec Posted 13 hours ago Share Posted 13 hours ago Hi guys, Not sure if this is the right area to post in. Sorry if it's not. I unfortunately have the code of ECU death (p0605). Symptoms are, the car has a rough Idle and anything below 2k rpm on the road it will all of a sudden drop 200-400 rpm intermittently. Anyone have any thoughts on possible repairs before I go get a new ecu or the current one repaired. Fuses? PCR Valve? Cam Sensors etc? Thanks guys! Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted 11 hours ago Share Posted 11 hours ago This might help: The diagnostic trouble code P0605 indicates an "Internal Control Module Read Only Memory (ROM) Error", meaning the PCM is experiencing an issue with its internal software storage, potentially requiring a reflash or module replacement. Here's a more detailed explanation: What it means: The P0605 code, which stands for "Internal Control Module: ROM Error," signifies that the Powertrain Control Module (PCM) has detected a problem within its internal Read Only Memory (ROM). What ROM is: The PCM's ROM stores the software that controls the vehicle's engine and other related systems. Potential causes: Faulty PCM: The PCM itself may have internal problems that are causing the ROM to fail. Software corruption: The software stored in the ROM may be corrupted. Bad solder joints or ground issues: Problems with solder joints or power/ground supply to the ECM can lead to this error. Aftermarket performance chips: If you have installed an aftermarket performance chip, removing it and clearing the code can resolve the issue. Troubleshooting and repair: Consult a professional: If you suspect a P0605 code, it's best to consult a qualified mechanic. Hard reset: Disconnecting the battery for 30 minutes to clear the memory to see if the fault comes back. Check connections and wiring: Inspect the PCM's power and ground connections, and ensure the wires are in good condition. PCM reflash or replacement: Depending on the fault, the PCM may need to be reflashed (reprogrammed) with the correct software, or it may need to be replaced. Show all Generative AI is experimental. Quote Link to comment Share on other sites More sharing options...
