shooter89 Posted February 11 Share Posted February 11 Hi all, The steering wheel on my 370Z moves side to side when I give it some power. I don’t remember my old 370Z doing this. Has anyone experienced this issue before? I’m thinking something might be loose. Thank you for the help in advance. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 11 Share Posted February 11 Is the steering column lock lever in the locked position? Quote Link to comment Share on other sites More sharing options...
shooter89 Posted February 15 Author Share Posted February 15 On 11/02/2025 at 17:22, ZMANALEX said: Is the steering column lock lever in the locked position? Hi ZMANALEX, It's been a while Around 10-12 years ago I bought some parts from you for my 350z :). I can confirm the steering wheel is in locked position I was going to remove the plastics today to investigate but it was raining, i will try remove it tomorrow. Quote Link to comment Share on other sites More sharing options...
shooter89 Posted March 1 Author Share Posted March 1 On 11/02/2025 at 17:22, ZMANALEX said: Is the steering column lock lever in the locked position? I can confirm this is now fixed. there were 12mm nuts holding the steering wheel the U-cip must of come out of its place. it was tricky doing it alone I was able to put it back in place and tighten the bolts. 1 Quote Link to comment Share on other sites More sharing options...
ShortPaul Posted March 2 Share Posted March 2 Good to hear you have sorted it, good work Quote Link to comment Share on other sites More sharing options...
